...we are leaving them basically stock. the wife has a set of rinehart slip ons that are epa compliant, and i have a set of cvo mufflers with stock baffles...
Just curious...did you retune the bikes after you changed the exhaust, and if so, how?
i think from what Im hearing from my dealer its more about the tuner than the exhaust. A good dealer might turn their back on the exhaust but cant fool Harley is an tuner other than HD has been used.
i shared this in another post. A week or so ago a customer with a new trike (150 miles I think) was having transmission problems. The shop tore it down and it was missing parts from the factory letting it slip out of 3rd gear when accelerating hard. Harley denied the claim due to a PV being used to tune the bike. No aftermarket cam or other motor work.
This is absolutely true! It has to do with the tune and not the pipes. The pipes do not have to be EPA compliant. The only requirement is the tune has to be a Harley Screaming Eagle Pro Street Tune which is EPA compliant. As long as Harley can show the EPA that they are only covering parts under their warranty that are tuned using their EPA compliant tuner, they are safe from EPA fines. If people like me, decide to put non EPA compliant pipes but still tune it with the Screaming Eagle Pro Street Tuner, then we are potentially liable for any EPA issues, not Harley - and that is all Harley cares about.
Maxwell talked about the DT II and what happens when it shows the tuning parameters are out of Harley's specifications. He said a window pops up and alarm bells go off. Then, the bike is flagged and the powertrain warranty is voided. I know people have said that the DT II knows if the ECM has been modified, even if the tune was put back to stock, but would the DT II show the same pop up, even if the tune was within Harley's specifications? Asking for a friend.
It doesn't matter if the tune is within Harley's specs or not. If the tune was done with something other than a HD Pro Street Tuner, then the warranty is voided - period. It doesn't matter if you tune it with an aftermarket tuner, like the Vance & Hines Fuel Pak 3, and then retune it with the HD Pro Street Tuner - Digital Tech will still know that the ECM was as some point flashed with something other than their tuner. Your bike will be flagged and your power train warranty will be voided.
Based off of my experience this isn't quite correct. If you take it in with a non compliant tune installed they will immediately flag it. But if you were to flash back to stock it would simply show how many times the bike has been flashed, and as long as you have purchased and installed the SE tuner this will not raise any flags. Now if you haven't that is an entirely different story.
What is the basis for your conclusion? Are you an H-D technician and have you actually used a DT II, and you have seen this with your own eyes?
I posed this question to John Maxwell and his reply was, "Im not sure if DT knows that it had ever been flashed or not."
The service mgr.At my local dealer said the mufflers are not the issue, It's the aftermarket tuners that Harley does not want on the bikes during warranty.He said as soon as they plug the bike in for any kind of service work all info goes directly to Harley Davidson.Harley Davidson is coming down hard on the dealers.
This is a dangerously incorrect statement. Read the decree and you'll see what I mean.
Every tune leaves a digital signature. Flagging has zero to do with "parameters". The ECM either has an approved digital signature that belongs to HD, or it doesn't. If it doesn't, warranty is flagged and voided.
This is a dangerously incorrect statement. Read the decree and you'll see what I mean..
It's a completely accurate statement. You can put whatever pipes or mufflers you want on your bike as long as it tuned with Harley's EPA compliant tuner. Harley is only responsible to the EPA for what they can show in their system. If your bike is tuned with an EPA compliant tuner, the EPA cannot come after Harley because according to Harley's record's your bike is EPA compliant.
So basically you are agreeing with me but just saying it differently - but yet the same. I think you are arguing just for the sake of arguing but yet agree with the overall point. However it is flagged, Digital Tech detects a third party tune and flags it. It definitely does not detect the kind of pipes or mufflers you have.
EPA didn’t “do” anything to Harley. Harley knowingly and deliberately violated federal law for years, and ignored all warnings from EPA and DOJ to stop it. Harley forced EPA and DOJ to take legal action against them for their illegal activities, and then settled the legal case before it went to court. EPA has no reason, cause, basis or legal authority to override the MM act.
In my opinion this is an over the top harsh assessment of Harley’s culpability. The ozone and particulate rules have been evolving for decades. Harley has tried to be compliant and at the same time preserve their brand and their image.....nothing wrong with that. The standards finally tightened to the point that H-D could no longer meet those standards with their engine technology as it was evolving. Enter the V-rod and now the Milwaukee 8. The touring models are most at risk because those are the bikes that will travel enough miles that emissions begin to matter over the lifetime of a bike. HD is still trying to avoid the completely water cooled technology jump that will ultimately be required, but it is coming.
It's just wrong to characterize the MoCo as deliberately violating laws....they were (just like everybody else) trying to comply with increasingly stringent air quality standards. The warranty issue is (trust me on this) just one more capitulation to an out of control regulatory agency. The MoCo will be forced down a path by EPA that will ultimately kill their uniqueness and eventually kill the company.
The best advice one could offer to their loyal customers is try and find the last year that H-D will make a bike that you would be willing to own. Keep it, modify it for all of its years.
The last great year to buy an HD is hard to predict, but it’s closer than you think.
