ABS brake bleeding
Old Jul 13, 2019 | 07:27 AM
RFC1962's Avatar
RFC1962
Originally Posted by e6fmf
Sorry to say I think you wasted your money. HD dealer had the equip. to flush safely, after all they are your brakes. Good luck and keep us posted, I hope I'm wrong, there may be another way after all.
After nearly 40 years of being a mechanic by trade, and building and racing and driving 200 mph race cars, I've come to the conclusion that "NO" mechanic cares for or works on your car or bike like you would if you had the skills to do it.
If I were to take the bike to the dealer they would charge more than what I paid for the tool. So, no I don't believe I wasted my money on this tool. Just add it to my arsenal.
Mike
Old Jul 13, 2019 | 07:49 AM
KumaRide's Avatar
KumaRide
The dealer told me the charge $90 when they did the recall last year. I know some one with a digiitech that charges less. HD recommends flush every two. That tool will pay for itself in 4 years
Old Jul 13, 2019 | 09:50 PM
skratch's Avatar
skratch
you're doing yourself a disservice if you don't have the dealer flush the clutch mc while you're at it. they both use the same dot4.
Old Jul 14, 2019 | 07:19 AM
RFC1962's Avatar
RFC1962
Flushing the fluids is different than what I needed this tool to cycle the abs module. I built my own vacuum pump assisted power bleeder to flush the fluids in the brake and clutch systems.
I needed this tool to bleed out some residual air left in the abs from when I changed my brake lines to braided SS.
Old Jul 14, 2019 | 08:58 AM
Reed's 1200's Avatar
Reed's 1200
6th Gear
On a related issue. The front brakes on my 2005 Police Road King w/ABS are not working right. The front brakes don't grab until the lever is pulled almost all the way back. And, they grab hard at that point. This does not improve when I pump the brake. I was going to try bleeding them but not sure if the this would be effective because of the ABS system. Excuse my ignorance on this issue as I just bought the bike and I have never had ABS on a bike before. Previous owner had not ridden it in several years. Any advice or help on proper procedure is appreciated.
Thanks.
Old Jul 14, 2019 | 09:45 AM
GalvTexGuy's Avatar
GalvTexGuy
Thanks.
When was the last time the brake pads were replaced? When was the last time the brake fluid was flushed?
Old Jul 14, 2019 | 09:51 AM
KumaRide's Avatar
KumaRide
thats what the dealer does for $90 - cycles the hcu. And thats what a Digitech does....
Old Jul 14, 2019 | 10:30 AM
alarmdoug's Avatar
alarmdoug
Originally Posted by Wisenheimer16
I'm probably going to catch hell for this but I'm a firm believer that changing brake fluid every two years is overkill
For what it's worth just about every motorcycle manufacturer in the world recommends brake fluid flush every 2 years. It's a small system and easily gets laden with moisture.
Then under extreme breaking conditions this moisture vaporizes and you lose your brakes. I know I did on a Yamaha a few years back on a Mountain Road no less. I lost my rear brake coming down a mountain with Luggage and my wife on the back. Was pretty darn scary, not knowing if I was going to lose the front brakes too, until at the bottom of the mountain which we made thank God about 15 minutes later it started working again once it cooled down.
I had no idea what was going on and then I learned about the mandatory two-year brake flush. In fact Yamaha recommends rebuilding the master cylinders and replacing the brake lines as well.
Then forget all the above if you're going to keep the bike a while changing the brake fluid will help all your braking components last longer because you're getting the moisture out of the system.
Old Jul 14, 2019 | 10:19 PM
Reed's 1200
6th Gear
Not sure. I just bought the bike. The previous owner had it for about 10 years but had not ridden it much for several years due to health issues. I guess he hadn't flushed the system during that time, if ever. The bike has 16,000 miles on it so unlikely it has needed new brake pads.
Can I just bleed the front brakes as normal to address my issue, or does the ABS system require special tools if I need to eliminate air in the system?
Old Jul 15, 2019 | 05:12 AM
GalvTexGuy's Avatar
GalvTexGuy
You can inspect the brake pads by sight. Though I have flushed the brake fluid without activating the ABS, the literature says you must activate the ABS when replacing or bleeding brake fluid.
Since the 2005 RK Police model was one of the first with ABS, I don't know if your bike has the same ABS module or, more importantly, the same HCU (hydraulic control unit) as the 2008-2011 models with ABS, but if it does, be prepared. In case you don't know, those model years were part of a NHTSA/Harley-Davidson recall. Many owners who took their bikes into the dealer for the brake fluid flush came away with a much larger bill than they anticipated. Even though the brake system may have been working fine before the recall, when the ABS system was activated for the brake fluid flush, many HCUs failed or locked up during the process, which required replacement to the tune of several hundred dollars.
Like I said, I don't know if your model has the same ABS/HCU as the recalled models. Even though, I would strongly suggest that you take your bike to a dealer to have the brakes serviced rather than doing it yourself.
