ABS brake bleeding
Old Jul 15, 2019 | 06:01 AM
alarmdoug's Avatar
alarmdoug
Originally Posted by Reed's 1200
Not sure. I just bought the bike. The previous owner had it for about 10 years but had not ridden it much for several years due to health issues. I guess he hadn't flushed the system during that time, if ever. The bike has 16,000 miles on it so unlikely it has needed new brake pads.
Can I just bleed the front brakes as normal to address my issue, or does the ABS system require special tools if I need to eliminate air in the system?
As far as Rushmore year touring bikes shop manual if your just flushing and replacing brake fluid you do it like you always have.
If air was introduced into the system, then you are not looking to flush the fluid, you are looking to bleed air from the brake system, ABS needs to be activated.
Old Jul 15, 2019 | 06:23 AM
GalvTexGuy's Avatar
GalvTexGuy
As much as I want to agree with you about flushing/replacing brake fluid on our Rushmore ABS bikes without activating the ABS system, or any ABS bike for that matter, that all changed with the 2018 service manuals. They added a step that includes using the DTII. Whether or not that step is included in newer printings of the service manuals (that step is not in my manual from 2014), I can't say, but I have had a change of heart when it comes to my ABS equipped '14 Limited. I was once a staunch advocate of replacing brake fluid in my bike without activating the ABS, but I'm not any longer. FWIW, I did fill out and send in the service manual Reader Comments page from the service manual pointing out the omission, but I haven't received a reply. I really don't expect to hear back, though. Anyway, I just thought I'd pass along the information.
Old Jul 15, 2019 | 08:35 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
...2005 Police Road King w/ABS...The front brakes don't grab until the lever is pulled almost all the way back. And, they grab hard at that point. This does not improve when I pump the brake.
Rather typical of dirty calipers where the pads stick on the rods, and the caliper pistons are sticking to the seals. Everything is being held back a little, resulting in excessive take-up play.
Old Jul 15, 2019 | 06:51 PM
Reed's 1200's Avatar
Reed's 1200
6th Gear
Thanks to all for the input. I haven't had a "new" bike in decades so I'm getting caught up on the tech.
I will call the HD dealer tomorrow and get an appointment to flush and check the system.
Old Jul 21, 2019 | 07:49 AM
alarmdoug's Avatar
alarmdoug
I certainly can understand your thinking so I am not disagreeing with what you chose to do for yourself. (please keep that in mind after my response below, just why I will not do ABS activation because HD doesnt call for it)
For me, I stick to the manual as there is no reason in my mind to activate ABS even though the new M8 bikes say too.
Countless never ending theories and posts on why someone should, but not for me, gosh why ever get on a bike.
If there was an issue with Rushmore bikes or ANY HD bike, there would have been a recall.
AS far as the recall on SOME pre Rushmore bikes, it was because of ONE reported minor injury PLUS other non injury reports of brake failure.
SO with the Federal Government and HD not admitting to a defect they decided to do a FREE brake fluid flush, because as best I know, in every instance, any case involving a non injury failure and the one case of a minor injury the people never changed their brake fluid. NOT ONE part needed to be replaced on the recall.
If there was an actual defect it would have had to be replaced but there was (in theory) a part in there that would corrode if people did not follow the simple maintenance schedule.
So for me, I dont need to read anything "between the lines"
The facts are from the Federal Governement and HD. No brake defects in Rushmore bikes (or any bike) and the maintenance manual stays the same for ALL HD bikes Pre 2017.
KumaRide
Jan 24, 2020 07:16 AM
Wisenheimer16
2014-2024 Touring Models
17
Nov 29, 2019 09:41 AM
Murderface
Feb 13, 2015 07:13 PM
strippedthread1
Wheels/Tires
Oct 13, 2011 06:39 AM
