Tune or not?
Old Jul 18, 2019 | 10:32 AM
dickey's Avatar
dickey
"anything but the HD tuner will mess with his warranty."
And, the HD tuner is about as useful as a rubber beak on a woodpecker.
Old Jul 18, 2019 | 10:34 AM
Gary1's Avatar
Gary1
Get you a K&N 1717 and go ahead a do a Stage 1 tune with a FP3. The air filter isn't much $$$.
Old Jul 18, 2019 | 12:00 PM
Griner's Avatar
Griner
1st Gear
I have a 2014 Ultra Classic I bought new. I added Street Cannon slipons right away.
This week I ordered a Vance & Hines VO2 air cleaner and a FP3.
The FP3 came 1 day before the air cleaner so I put it on and did the setup. That by itself made a big difference. I was surprised.
The next day I added the air cleaner and that made another difference.
So yes, the FP3 alone will make a difference.
Old Jul 18, 2019 | 04:54 PM
steelerdude1's Avatar
steelerdude1
Originally Posted by rozemab
I was wondering if a bone-stock bike would benefit using a FP3 etc. . Sounds like you're happy of the results.
You said reduced heat off the bike. Can you explain please?
Did anything change with the new map? Better cold start, cold start idle, reduced deceleration 'popping' etc ?
Been on the fence for awhile about jumping into the game.
Been any regrets ?
Heat: The heat from the Cat on my right calf was so bad I would feel like I was getting burnt, to the point that I would stop to see if I was blistering. - Never did get blisters or welts, but it would be red. - The FP3 got rid of what I felt was excessive heat.
Changes: - Never had any issues with cold starts, or decell popping, but I do notice better performance with the aggressive throttle setting, my red line cut off is now at 6200 RPM’s rather than the stock 5200, and my exhaust note is better/deeper.
I have no regrets, and as stated, wished I did it sooner.
Old Jul 18, 2019 | 05:07 PM
rozemab's Avatar
rozemab
Thanks for the feedback!
Old Jul 20, 2019 | 01:08 AM
flash1034's Avatar
flash1034
Thanks for the responses. My bike is a CVO so it already has the high flow air cleaner. I put 2” Fullsac CVO Power Core inserts in the stock pipes. The only reason I’m hesitating with the tuner is my warranty.
Old Jul 20, 2019 | 05:12 AM
Mofo67's Avatar
Mofo67
Flash - I have a ‘19 CVO Mako with S&S slip ons. Bike runs great and I do not have a tuner. Would a tuner help, maybe a little if you use the SEPST but any aftermarket tuner will void your warranty. Harley is making it increasing difficult to go aftermarket.
Enjoy that great looking bike..
Old Jul 20, 2019 | 09:09 AM
hattitude's Avatar
hattitude
You can use the HD CARB approved tuner until you're off warranty... while not optimum, it's better than nothing....
I've never used it, but I think you should be able to download a Stage I tune and I think I've read where you can do some minor auto tuning with it... I'm sure someone with experience with the tuner will correct me if misunderstand it's capabilities...
It will all be an EPA approved tune (= a little lean), but will you through your warranty period... If you don't like the way it runs, after the warranty is up, you can get a better tuner/tune...
jp13
Exhaust System Topics
May 18, 2016 11:30 AM
streetglide6
Jul 6, 2015 08:57 AM
JCloud
Feb 19, 2013 09:30 PM
RJHD
Dec 16, 2012 07:00 AM
tstammer
Aug 24, 2012 07:56 AM
