Molex plug ( pins )
Old Jul 18, 2019 | 08:54 PM
bitchn bob's Avatar
bitchn bob
2nd Gear
Default Molex plug ( pins )
Do we have to order pins through Harley Davidson in order to replace pins in the connector on the throttle body of a 09 ultra , and also can these be soldered instead of crimped
Old Jul 18, 2019 | 09:25 PM
dawg's Avatar
dawg
No, Drag Specialties and others have the pins. They can also be cut and soldered (lengthened) or can be removed from connector and crimped with proper tool and reinstalled
Old Jul 18, 2019 | 09:52 PM
hattitude's Avatar
hattitude
You can even get the parts on Amazon.....
Amazon Amazon
Old Jul 19, 2019 | 08:37 AM
Ssitruc's Avatar
Ssitruc
If you get a proper crimp tool you'll forget about soldering them too... mine is the kind that makes both of the crimps at the same time (with one click) and it is solid and doesn't deform (bend) or tweak the pins in the process. Which is what would happen using my cheapo crimpers I had laying around. I used to solder mine too, just seemed "better", but after getting the proper tool I don't think its necessary at all and its so much simpler.
Old Jul 19, 2019 | 09:01 AM
2slow05's Avatar
2slow05
what crimpers do you use
Old Jul 19, 2019 | 09:18 AM
Magnut1's Avatar
Magnut1
If I need the pins right now, I go to the dealer and they have them in stock usually. They aren't very much and convenient if you just need a couple and like Right Now.
Old Jul 19, 2019 | 10:19 AM
larsfum's Avatar
larsfum
I have used this one before. Doesn't break the bank and does a good job.
Amazon Amazon
Old Jul 19, 2019 | 10:55 AM
Ssitruc's Avatar
Ssitruc
I have a set like this one
Amazon Amazon
Old Jul 31, 2019 | 01:51 PM
MegaJohn's Avatar
MegaJohn
Deleted... found my answer.
Old Jul 31, 2019 | 09:21 PM
langwilliams's Avatar
langwilliams
thanks for the links to the crimpers. I replaced the twist sensor an the wire it plugs into. occasionally I get a CEL when I crank the bars stop to stop parking. It goes away after shutting it down then restarting it a few minutes later. I'm thinking it's the pins on the connector inside the fairing to the harness. That will be job one when the riding season is over.
