Right lower fairing vent
Old Jul 21, 2019 | 08:03 PM
CanuckEH's Avatar
CanuckEH
Default Right lower fairing vent
so, I found this when I parked today. The Right side vent sheered right off. It looks to be sheared from the swivel handle. What part do I need to get this fixed?
Old Jul 21, 2019 | 08:11 PM
cncmike's Avatar
cncmike
http://partsfinder.onlinemicrofiche....SACEgKnbPD_BwE
i would look up the part number for you but you didnt give enough info on your bike. Save this site. I use it all the time.
Old Jul 21, 2019 | 08:17 PM
CanuckEH's Avatar
CanuckEH
Default Thanks
Thank you CNC mike, I did just that from an earlier post with the link.
I have the parts already saved in a basket.
What I am confused more about is the part which is broken from inside the door, or the actual vent piece itself. It's hard to discern from the blow up diagram.
I will be taking the lowers off tomorrow and take a better look. Was just attempting to get ahead of the curve ball.
2008 FLHTCU
Cheers
Old Jul 21, 2019 | 08:34 PM
cncmike's Avatar
cncmike
You need part #21 Tray,glove box. You can't see in the online drawing, but the floor of the tray has a square hole in it. In your picture there are a stack of items under the nut. One is a serated white plastic washer with a square center. If you loosen the nut you will find a chunk of the tray floor with a portion of that square hole. The edge of the tray from the square hole outwards is broken off and still attached to your door. That issue and the fact that the slot in the door is broken at the end are both issues I have dealt with. I currently have my doors removed for the summer.
Old Jul 22, 2019 | 12:11 PM
hdbob2006's Avatar
hdbob2006
I put mine back together with JB Weld,but it looks like I had a little bigger piece broken out.
Old Jul 22, 2019 | 02:24 PM
jberg's Avatar
jberg
Mike is correct.
This happened to me when the bike was no more than a year old. It was repaired under warranty and it's been solid for at least 8 years.
Old Jul 22, 2019 | 05:06 PM
2slow05's Avatar
2slow05
mine has the same issue as his, it appears to be part number 19 on the description tray, glovebox.
JakeUSAF
2014-2024 Touring Models
Jan 2, 2018 07:06 AM
Spikehorn
Jun 9, 2016 07:36 PM
pt4u2nv
Apr 23, 2014 07:00 PM
Pastor John
Mar 17, 2009 10:32 AM
Blacklion213
Oct 22, 2008 09:12 AM
