Clutch diapharm color code
Old Jul 29, 2019 | 10:16 PM
Big Dave's Avatar
Big Dave
Default Clutch diapharm color code
My 09 ultra has a red paint splash on the spring , on higher rpm shifts i only have to touch the clutch lever and the clutch starts slipping , so with my modes i think im on the cusp of a problem
What color would be the next level of tightness with out going to so heavy a lever pull, no money as usual so wondering what the next heaviest would be
Thanks
Dave
Old Jul 30, 2019 | 12:51 AM
bklynbob's Avatar
bklynbob
No idea on red,never heard of it. Im using 37871-98a not stiff,holds well. $25.
Old Jul 30, 2019 | 07:19 AM
SBates08's Avatar
SBates08
I know it's far more than the price of a clutch spring but you'd never have to worry about slippage again.
Amazon Amazon
Old Jul 30, 2019 | 08:31 AM
roussfam's Avatar
roussfam
Thanks
Dave
Yes they are color coded. Seen a listing here years ago. Hopefully someone will be along soon with more info.
Jim
Old Jul 30, 2019 | 10:17 AM
Big Dave's Avatar
Big Dave
I don't know Orange maybe ?
Dave
Old Jul 30, 2019 | 04:47 PM
CSMHOG's Avatar
CSMHOG
On an 09 bike, could it be that your springs are just worn?
Old Jul 30, 2019 | 05:17 PM
99Birdman's Avatar
99Birdman
FWIW:
37882-06A blue dot (260 lbs/ft) 2006-88", 2007 thru 2010-96"
37871-04 yellow dot (300 lbs/ft) 2004-05 88" and 2010 Limited
37871-98A (320 lbs/ft) 1998-2003
37807-03 pink dot (365 lbs/ft) 2007 thru 2010-103 "Police"
37951-98 (385 lbs/ft) Current SE
And from another source:
37882-06 (117 KgF) 2006-88”, 2007 thru 2010-96”
37871-04 (135 KgF) 2004-05 88” and 2010 Limited
37871-98A (145 KgF) 1998-2003
37871-98 is reportedly the same as above except cheaper, but although is no longer available may still be in dealer inventories.
37807-03 (165 KgF) 2007 thru 2010-103 ”Police"
37951-98 (175 KgF) Current SE
Old Jul 30, 2019 | 05:34 PM
SBates08's Avatar
SBates08
For what it's worth, the yellow dot on my 2010 Limited slipped with only a Stage 1 upgrade. Got really bad after cam upgrade and wouldn't stick for **** after the FM107.
Old Jul 31, 2019 | 11:41 AM
Big Dave's Avatar
Big Dave
Thanks guys I found a 37871-98 NOS rated at 320lbs for $17.00 , Cheap enough to try
Dave
Old Jul 31, 2019 | 12:19 PM
Big Dave's Avatar
Big Dave
So what are the odds of being able to changing the spring through the Derby cover ?
Dave
