Solo tour pak with.....
Old Aug 8, 2019 | 08:08 PM
AliensilverFXDBI's Avatar
AliensilverFXDBI
Default Solo tour pak with.....
Quick detach luggage rack behind it. Anyone using a setup like this?
Old Aug 8, 2019 | 10:56 PM
Circa58's Avatar
Circa58
yes
Old Aug 8, 2019 | 11:26 PM
RichM752's Avatar
RichM752
Working on it now. Just ordered the stealth two up rack, with a plan to modify it, to fit behind the solo mounted tour pak.
Old Aug 8, 2019 | 11:40 PM
AliensilverFXDBI
Post pics when you get it dialed in. I want to use my tour pak with a solo seat and put my king luggage rack behind it.
AliensilverFXDBI
Originally Posted by Circa58
yes
Do you have a tour pak? Or just the solo seat?
Old Aug 9, 2019 | 05:56 AM
Circa58's Avatar
Circa58
My bad, yes I do have a solo mount tour rack but I have not put the luggage rack behind it yet, I'll try to install it this weekend
Old Aug 9, 2019 | 06:51 AM
AliensilverFXDBI
Roger that. I'm curious to know if it's possible and how it looks. Thank you.
Old Aug 27, 2019 | 11:54 AM
RichM752's Avatar
RichM752
The only luggage rack I found that mounts in the two up position with the solo mounted tour pack is the stealth version. I found a used genuine stealth rack on eBay. The chinese versions are built with inferior materials IMO. Removed the stealth bars, and had a buddy fab the longer/lower extension that fastened to the existing mount. It will work for me when going on an extended camping trip.
Old Aug 27, 2019 | 02:06 PM
Hammerdown77's Avatar
Hammerdown77
Me also. I just got a Givi case mounted to my solo tour pak rack, and would like the option of carrying a drybag behind it as well.
Old Aug 27, 2019 | 04:46 PM
Mountainkowboy's Avatar
Mountainkowboy
Kinda......
