True dual performance
Old Aug 29, 2019 | 09:59 PM
handirifle's Avatar
handirifle
Default True dual performance
Let me state upfront I do not have a big twin, yet! But I often read of someone installing true duals. Is there a performance hit or gain when making this switch, from a system with a built in crossover?
Is a 2-1 the best power producer for big twins like it seems to be for sportsters?
Old Aug 30, 2019 | 03:12 AM
CGLTD's Avatar
CGLTD
inherently, yes, not by very much from what I can "feel"
no
yes but don't know if "like a Sportster.
Old Aug 30, 2019 | 03:18 AM
shrekmoose's Avatar
shrekmoose
It also depends on how you ride the bike. Are you cruising around and wanting the botttom end torque to pass without shifting? Or are you like me and riding the fire out of it in the top half of the rpm range. I’ve found the duals suit me better than a 2-1 for my style of riding as they seem to breath a little better up top. But the low end lost is hardly noticeable and it’s still very easy to just putt putt around and cruise.
Old Aug 30, 2019 | 05:41 AM
grbrown's Avatar
grbrown
I've had true duals and a 2-into-1 on my Glide and had both set up on the same dyno. by the same operator. The headline numbers were very close, so if comparing max HP and max TQ there was little to choose between the two. The difference is that the 2-into-1 system gives significantly more low/mid range torque, for the rev range many of us normally ride in, but the unexpected bonus is how much smoother running my bike is with the 2-into-1. That alone is worth the swap, with the better rideability and comfort. I have no plans to change!
Old Aug 30, 2019 | 06:54 AM
Notgrownup's Avatar
Notgrownup
I like the 2in1 the best of the 3 set ups I’ve had. The low to mid power is very nice to have. The highway passing power is the best I have ever had.
Old Aug 30, 2019 | 10:09 AM
handirifle's Avatar
handirifle
Great thanks guys. Experience is always the best.
Old Aug 30, 2019 | 03:43 PM
Vernal's Avatar
Vernal
Check out the dyno charts and I think all your questions will be answered. https://www.fuelmotousa.com/p-33193-....html#rushmore
I had V&H Dresser Duals on several bikes then switched to Power Duals. I like the power duals but if I ever change exhaust again I'll look for a 2:1.
But the charts above take the guesswork out of the equation.
Old Aug 30, 2019 | 04:55 PM
handirifle's Avatar
handirifle
Vernal
Yup thanks. That really showed the difference in true number form.
ridedaddy
Aug 28, 2014 04:26 PM
Zooki1
Exhaust System Topics
Feb 14, 2013 07:33 AM
mgmmgm
Nov 6, 2012 06:17 AM
Turbo Flux
Dec 2, 2010 09:10 PM
nxcesshog
Mar 22, 2007 12:08 PM
