Voltage Meter Question
Old Jul 14, 2007 | 01:01 PM
russl179's Avatar
russl179
Default Voltage Meter Question
When I start my bike, the meter reads 14 volts. After the bike is riding for awhile, the meter goes down to just above 12 volts. Is this normal? I have a 2007 FLHTC. Thanks!
Old Jul 14, 2007 | 01:35 PM
Peekaboo Bob's Avatar
Peekaboo Bob
Default RE: Voltage Meter Question
It would not be normal for my bike. Mine goes the other way, it starts around 12.5 and goes up to a little over 14 after riding a while.
Old Jul 14, 2007 | 03:58 PM
robbitybob's Avatar
robbitybob
Mine also begins at 12.5 or so and then stays at a tad over 14
Old Jul 14, 2007 | 04:57 PM
stro1965's Avatar
stro1965
Mine idles around 12 and out on the road it reads 13.5. I told the dealer, after they verified that the charging system was working properly, that I wanted a new gauge. He said something to the effect of "well, they're not meant to be that accurate anyway". Huh? We straightened it out, I'll be getting a new, accurate gauge, at my 5K.
Old Jul 14, 2007 | 06:08 PM
Seaquester5's Avatar
Seaquester5
I am not sure motorcycles are different, mine does not have a voltmeter, but typically 12 volt systems show 13.5-14.5 volts on start up reflecting the charge rate after the load from start up and then as the system charges it reduces to about 12.5 volts.indicating the battery is fully charged.
Old Jul 15, 2007 | 09:40 AM
st john's Avatar
st john
Interesting, when I hit the start button it drops to 10.5. at idle 12.5 and
when on the road 14. been doing this for 8 years new battery or not.
The only time it changed is when I noticed the ground had came a little
loose at the frame. Of course mine is considered an old bike, 2000 FLHT.
LOL
Saint
Old Jul 15, 2007 | 06:39 PM
Retired_Ted's Avatar
Retired_Ted
A new, good battery will measure 12.8-12.9V when fully charged with NO load (calibrated, sensitive meter, not the meter on the dash). If the voltage at rest is 12.5, it's about 50% charged (assuming lead acid). When the engine is at fast idle, say 1500 to 2000 rpm's the voltage will increase to 14.3 volts plus or minus a little. Anything over 14.5 would make me suspicious of the voltage regulator. HD hasn't made a reliable voltage regulator in its history, btw. If the engine's just idling (900 rpm), the charging system probably can't keep up with the current draw of all the lights and the battery will slowly discharge meaning its voltage will slowly drop below 12.6 volts.
Frogprince
Apr 9, 2024 10:08 AM
rhuff
Sep 17, 2017 09:33 AM
0maha
EVO
Oct 9, 2015 06:06 PM
keno
Jan 5, 2013 12:03 PM
scottdoege
Mar 29, 2009 08:59 PM
