voltage gauge question
Old Jan 4, 2013 | 10:05 PM
keno's Avatar
keno
Default voltage gauge question
New 2013 EGC and the voltage gauge is running at about 15.. Is this normal or does that seem high?
Old Jan 4, 2013 | 10:12 PM
79289Chase's Avatar
79289Chase
My friends new 2013 road glide does the same and it makes me question my 2009 that runs right at 14v on the gauge. I was wondering what was considered normal and correct?
Old Jan 4, 2013 | 10:17 PM
Duke 07's Avatar
Duke 07
Sounds about right to me. 14-15 volts sounds about right. I wouldn't worry about either one of them.
Old Jan 4, 2013 | 10:21 PM
keno's Avatar
keno
Good to know. Thanks guys..
Old Jan 4, 2013 | 10:27 PM
Lowcountry Joe's Avatar
Lowcountry Joe
That gauge is not a precision instrument.
Old Jan 4, 2013 | 10:33 PM
pastime's Avatar
pastime
Smile
Yup.....sounds right. Interestingly enough the owners manual (for those that ever bother to crack it open) doesn't tell you this is "normal".
Old Jan 5, 2013 | 12:29 AM
rpking's Avatar
rpking
my 2013 Street Glide runs what I think is "high" also, always 15 or a tad more, I haven't checked it with a multi meter yet, but I bet it will show the gauge is off.
Old Jan 5, 2013 | 07:07 AM
tango202's Avatar
tango202
My '00 shows a bit less than 14 at the gauge, and 14.6 at the battery.
Old Jan 5, 2013 | 08:12 AM
mkguitar's Avatar
mkguitar
The charging system "should" supply 14.7* volts to the battery at motor speeds above 2000 rpms or so.
14.7 is enough to recharge the battery and keep everything running.
Voltage above 15 volts will burn up the battery in time, leading to failure.
The voltage regulator does 2 things.
1.) converts the AC voltage from the stator to DC
B.) limits the DC voltage to below 14.7
High voltage reading may indicate the VR is failing.
The dash "instrument" is not finely calibrated and the wiring to it may show "voltage drop". Confirm readings with a real voltmeter ( as in the post above).
Riders can get an idea of what is "normal" on their bike- and pay attention if readings are higher or lower than the usual observed range
Mike
* or 14.8 volts, either is acceptable
Old Jan 5, 2013 | 08:27 AM
BIGRED1's Avatar
BIGRED1
My '12SG always pegs the meter out. Idid check the system with a multi-meter and it charges around 14.2 or so.
As said before, get to know the meter and if it acts differently, there may be a potiontial problem lurking.
Roger
