this usb is awesome, on my tour pack I had spliced into the light was good to go in all weather, but the RK im still thinking.
Where do you charge your phone on your Road King?
Don't have an RK (Street Glide) but i bought a USB port that fit into my cigarette lighter spot....has two ports and a cover... simple and out of the way. Perhaps you can do some searches for various USB ports...I've seen for handle bars, bags, etc. A bit of creative thinking may give you a spot to place this. I'll charge while riding, but do not access/use the phone except for music. Hard enough to look out for a$$holes out to kill you let alone try to converse! I digress.... Check for ports.... mount to handle bars, engine/saddlebag guards, find a spot not readily visible, or one of the side covers. Let us know how it goes.....
What I did was use an extra battery tender cable and soldered an extra length of cord to it and ran it under my tank bezel and up into my leather pouch on the windshield . Phone is now out of the elements , and I can also mount it when I need gps or etc .
If your RK is 09-13 ( I know for a fact ), look about 6'' back from your headlight plug for a orange wire with a white stripe and a black wire along side of it, both will have blade connectors already on them. This is a switched power source, headlight on you have power, headlight off, no juice. Orange is your positive, black is your ground.
How about adding a cigarette lighter socket under your seat . Run the car charger wire under the tank . Plug in the charger and tape everything up tight so it doesn't come apart . Thats what I do !
