Missing bolt on SHift Linkage
Old Sep 23, 2019 | 08:25 AM
Dave Fares's Avatar
Dave Fares
Default Missing bolt on SHift Linkage
The bolt came out on the back side of the shifter linkage that holds the transmission shift lever tight to the shifter shaft. Anyone know what the part number is or exactly what size this is. Hate to have to buy the entire shift lever arm for a single bolt.
thanks
Old Sep 23, 2019 | 08:40 AM
Uncle Larry's Avatar
Uncle Larry
http://partsfinder.onlinemicrofiche....TER%20ASSEMBLY
#856a
856A SCREW, 5/16-24 X 1 knurled socket hd
Old Sep 23, 2019 | 09:10 AM
RK_Classic's Avatar
RK_Classic
Run out to your local hardware 5/16-24 X 1
rk classic.
Old Sep 23, 2019 | 09:49 AM
Fireball Jack's Avatar
Fireball Jack
Use some blue loctite.
Old Sep 23, 2019 | 10:20 AM
hardheaded's Avatar
hardheaded
Or install a grade 8 bolt.
Old Sep 23, 2019 | 11:54 AM
Dave Fares's Avatar
Dave Fares
Thanks, I have to pass a dealer on the way home, I may stop to see if they actually have it, if not, the hardware store I go.
Old Sep 23, 2019 | 12:06 PM
bagga's Avatar
bagga
hardware store would be way cheaper.
Old Sep 23, 2019 | 05:45 PM
NELS's Avatar
NELS
FWIW: True Value here has chrome and stainless cap screws and nuts. Don' t know where you live though.
Old Sep 24, 2019 | 12:54 PM
Dave Fares's Avatar
Dave Fares
it was only 54 cents at Harley and had to pass one on the way home. Seems the shaft splines are worn, since I bought it used, who knows what may have been done before me. Looks like I need a new shaft and shifter arm as well. Might as well replace them now before I get stranded somewhere
thanks
Old Sep 24, 2019 | 03:21 PM
05UltraBob's Avatar
05UltraBob
thanks
Easy and quick to repair. I actually carry all those parts in my saddlebag, along with the required tools, as they strip and break often enough if you ride a lot!
