Air shocks
Old Oct 5, 2019 | 10:30 PM
JtQuinn's Avatar
JtQuinn
6th Gear
The gauge on the dash goes to 90-100. Today we didnt ride as far. Preassure was 30 when we left but got up to 70 after a while. Rode good at 70psi with two. Bike has true dual exhaust. Maybe heat is a factor. I dont want them blowing out on me.
Thanks for all the feed back. Will be doing a change over this winter.
Old Oct 6, 2019 | 02:18 AM
r0de_runr's Avatar
r0de_runr
I don't think there is an air pressure gauge in the dash for the rear shocks. At least not stock.
The air valve on my '14 limited is between the left saddlebag and the frame just below the seat. Check it there with the proper pump/gauge.
For a couple of bucks you can replace the air lines with fittings from a hardware store and adjust them individually. I replaced the oil in my shocks and put back in a little less (10oz instead of 12 of 10wt) and run 20lbs of air in each. Reasonably happy with the ride.
You're not going to get much out of any shock with just three inches of travel.
Old Oct 6, 2019 | 05:54 AM
grbrown's Avatar
grbrown
I suspect there is more to this than meets the eye! Any air gauge on the dash has been added by a PO, which in turn begs the question what else has he added? I don't know of any stock air shocks that will go to 100psi, that is way over the top of the recommendations. H-D air shocks have changed spec over the years from around 20psi max to 50psi max. A photo of your shocks would be interesting to see. I also have Ohlins #3-3 shocks, which are wonderful!
By the way, it sounds as if you don't have an owners manual for your bike. You can download one from the H-D website, via the Owners tab.
Old Oct 6, 2019 | 07:04 AM
KYRGultra's Avatar
KYRGultra
Bought a new '13 RGC, air shocks seemed OK for about 2 years then started slowly leaking down. The leaking down got worse, I replaced them with the HD hand adjustables. WOW! Much better ride.
So 2+ years ago I bought a garage queen '16 RGU. Soon as I got home I ordered the HD adjustables from one of the dealers that discounts online. The OEM air shocks suck!
Old Oct 6, 2019 | 09:29 AM
hattitude's Avatar
hattitude
I suspect you have an aftermarket air ride system.... There is no shock pressure guage, on OEM shocks from the factory. As mentioned, the HD shocks have a max limit about half of 100psi, Harley shocks would pop at 100psi.....
Old Oct 6, 2019 | 11:02 AM
langwilliams's Avatar
langwilliams
yeah kinda sounds like a DIY air ride.
is there an onboard compressor that airs them up?
Old Oct 6, 2019 | 06:19 PM
Spartanden's Avatar
Spartanden
I believe you see the air temp gage.... it says AIR and is a gage.... this is a thermometer. There are no air pressure gages for your shocks. I ran 40-50 pounds in mine depending.... and you had to measure air pressure through the Harley pump/gage. I saw a thread once where the OP kept adjusting his shocks based on the air temp gage.... was quite frustrated with the results until he figured out which was what!!!
Old Oct 6, 2019 | 07:19 PM
JtQuinn's Avatar
JtQuinn
6th Gear
Like you folks have said. Read the book. Dont listen to the salesman. Not sure why it reads 30 everytime I turn the power on. But yes it is ambient air temp. Guess who feels like a idiot. I bought a HD hand pump yesterday and put 45psi in it. Road great today. Thanks again.
Old Oct 6, 2019 | 07:32 PM
Red's Avatar
Red
Do you also own a '13 and not a '14? I'm just curious! Maybe it's the digital readout of the '14 you're talking about. Had me confused because you were confused.
Enjoy the new ride...
Old Oct 6, 2019 | 10:02 PM
miner999r's Avatar
miner999r
I keep my air shocks pumped into the high 40 psig range. The bike rides much better when the air shocks are near max even when solo. Also recommend running the SE heavy fork oil as it tames a lot of the stock forks bad behaviour. Plus it is a lot less costly than chasing expensive suspension components. I prefer a firm ride and what I do does not make the ride harsh.
If you are a high performance rider the expensive stuff might be worth it.
TexasMotorcycleRider
2014-2024 Touring Models
35
Sep 19, 2016 11:14 AM
Davemac122383
May 26, 2014 07:11 AM
manzo
Mar 18, 2014 07:08 PM
cbears
Jul 6, 2010 12:29 PM
davidw221
Sep 18, 2007 08:18 PM
