Considering a engine upgrade
Old Oct 15, 2019 | 04:40 PM
miner999r's Avatar
miner999r
Might want to consider the stock head pipes if you still have them, gut the cat and use your existing slip on mufflers. Or often you can find someone offering stock headers with a gutted cat. This would be in my opinion the most economical means to regain some torque.
Old Oct 16, 2019 | 12:35 AM
rhuff's Avatar
rhuff
107" is no biggie, but you start looking at other things with that many miles and age IMO. It's just a roll of the dice. I personally wouldn't do the build without have the crank looked at. At that point, I say do the whole thing and have the crank R&R by Darkhorse and do a case bore to get 117". But now you're all in for a new exhaust too.
So what would I do? Get a late model Rushmore 103 or a used M8 and get more power, less miles, and a newer bike for probably 5-10K instead of spending 2-4K on a 107 kit that will need new header, tune, etc. Or be happy with what you have.
Old Oct 16, 2019 | 04:03 AM
sanman4ever's Avatar
sanman4ever
Do the FM 107. I don't think I've ever read one bad post about someone being unhappy with the outcome. Aside from exhaust and tuner might want to consider a clutch upgrade too.
Old Oct 16, 2019 | 05:02 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by Andrewwayne
Thanks for the information. I don’t ride too aggressive but do like to twist it every now and then, but rarely exceed 4500 rpm my main reason would be to get a little more power and i like tinkering with stuff. Would I be better with a stock head pipe than with the duals? I really don’t want to change pipes these are less than a year old
What you rally want for that rev range is more torque, rather than power, which is where a proper 2-into-1 comes into its best. My old Glide has an S&S 107" and I have had both TDs and a Supertrapp 2-into-1 dyno set-up. Headline numbers for both were very close, not enough to argue over, however low/mid range torque was as much as 15% better with the 2-into-1, with the added bonus of the engine running much more smoothly. That alone is worth the change from TDs IMHO.
Old Oct 16, 2019 | 09:41 AM
hattitude's Avatar
hattitude
I'm partial to FuelMoto. They're doing an engine upgrade for me in two weeks... but there are many good shops represented on this forum, with their own engine upgrade parts preferences...
Whatever shop you plan to use, contact them. If you are going to use their combination of parts for an upgrade, chances are they have installed/tuned many versions of that upgrade. Tell them what your goals are, and then follow their advice.....
If you use the FuelMoto 107 kit, I suspect they will tell you to lose the dual exhausts for best results.....
roadking2014
Jul 4, 2018 01:10 AM
devilsdelight
Feb 22, 2018 12:10 PM
Litewings
Oct 1, 2017 10:48 AM
waltz4
Sep 18, 2014 11:13 PM
Road King Kid
Exhaust System Topics
59
Aug 15, 2009 04:22 PM
