15" Ultra Limited - Looking for the best Rear Brake Controller, I want something that will flash all of the lights when braking. I have the typical fender light, tour pak lights and I also have the Saddle Bag Run/Brake light https://www.harley-davidson.com/stor...11-67800449--1
So which run/brake controller is best?
Your bike has two separate rear lighting harnesses - 1 for the Tour-Pak, and one for everything below the Tour-Pak. We make our Magic Strobes LTP2 to strobe the Tour-Pak, and for your fender light, you can use the Magic Strobes BCM or Magic Strobes RSG. The RSG is designed so that you can also run our Fillerz lights; the BCM will only strobe the center taillight.
In general, we find the Harley Electra-Glo bag lights are not compatible with our products due to how much power they draw. You can still run them on the bike, of course, but our modules have to be plugged in after the bag light harness so that they aren't affected (the bag lights won't strobe).
Thank you, very helpful! I just ordered the LTP2 for the Tour-Pak. Given the fact I have the HD Electra Glo saddlebag lights, do I install the LTP2 per the instructions?
@sixgun95 , you are welcome! You can install the LTP2 into your Tour Pak harness per the instructions. The Electra Glo lights should be hooked into the harness that runs your rear taillights; so they won't affect and will not be affected by the LTP2.
If you have any questions when you are installing it, just give us a call at 800-382-1388!
