Turbine wheel on a 2014 street glide standard
Old Nov 22, 2019 | 06:59 PM
smdusaf's Avatar
smdusaf
Default Turbine wheel on a 2014 street glide standard
So I have a 2014 street glide standard and just bought a turbine wheel off a 18 special. I know I need non abs bearings but what do I do about the brakes. Thanks in advance.
Old Nov 22, 2019 | 07:31 PM
Jaftica's Avatar
Jaftica
Brakes are the same. Only difference in abs & non abs is the bearing and the sensor/spacer which you don't have if you don't have abs.
Old Nov 22, 2019 | 07:55 PM
smdusaf's Avatar
smdusaf
So my rotors from my enforcer wheels will bolt up to the turbine wheels
Old Nov 22, 2019 | 07:58 PM
caulk04's Avatar
caulk04
I can't picture that wheel off hand, but if it looks like the rotors fit, yes. Otherwise you'll need the typical touring rotors that bolt on near the hub.
Old Nov 22, 2019 | 08:14 PM
Jaftica's Avatar
Jaftica
Is this the wheel your taking about?
Old Nov 22, 2019 | 08:17 PM
smdusaf's Avatar
smdusaf
Yes it is
Old Nov 22, 2019 | 08:30 PM
langwilliams's Avatar
langwilliams
nice...wish I could find a deal on some
Old Nov 22, 2019 | 08:48 PM
Jaftica's Avatar
Jaftica
And these are the wheels you have now? If so, the rotors will not work.
See the source image
Old Nov 22, 2019 | 09:33 PM
smdusaf's Avatar
smdusaf
Anyone have any idea for some affordable options for rotors I guess then
Old Nov 22, 2019 | 10:28 PM
Chad1200's Avatar
Chad1200
Your best bet is to probably get the same rotors that are used with that wheel on the Street Glide if you want the best possible fit with no worries.
