Performance packages
Old Jul 17, 2007 | 10:03 AM
murraypj's Avatar
murraypj
4th Gear
Default Performance packages
I saw a post awhile back that had some web site that had different performance packages and I can't find it. I would like to do a 110" on my '07 FLHX can someone give some recommendations on some good kits. Thanks
Old Jul 18, 2007 | 04:17 AM
PapaTravis's Avatar
PapaTravis
Default RE: Performance packages
Try : http://www.gmrperformance.com/ also, http://www.head-quarters.com/Hope this helps. From what others have posted on this site, you can call either. They are very informed and know their stuff, so I have read. I have a tc88 and plan on doing the 98" kit from GMR, once I can get some scratch up (maybe a winter project).
And, if it has not been mentioned before: WELCOME to the forum. I am a little surprised noone has given you a link yet. I get online late at night after work, and usually everything I have to add to a post has already been sadi, LOL. If you need anything, don't hesitate to ask. Oh, also check out www.nightrider.com , lots of good information here.
Old Jul 18, 2007 | 04:21 AM
Abnmarine's Avatar
Abnmarine
GMRPerformance 07 power pack 107
We have a great kit for the guys and gals with the new 07 96 cubic inch bikes. Being that the 96 inch engine already has a stroker crank stock, we offer a bolt on cylinder and piston kit that will take you beyond the 103 level straight to a 107 inch. This is CNC porting your heads.This kit with the flat top piston will yield 10.1 compression based on stock cc volume. Compression can be raised or lowered if you so desire. This kit has made 121hp and 128 tuned
¡ 10.1ForgedJE pistons with rings, clips and pins
¡ Andrews 55g cam and install kit
¡ Complete MLS top end gasket kit
¡ Stage III CNC-Cutting your heads cut on 6 axis CNC
¡ New guides tapered and diamond honed
¡ New viton seals
¡ New Ferrea 1.9 intake valve
¡ New Manley 1.625 exhaust valvescut down ( that allows a 80% margin= great for flow) full radius valve job
¡ Milled to CC needed for compression based on cam choice
¡ New springs and set to correct seat pressure for the 55G
¡ Machine and install compression release's
¡ GMR custom made chromemoly 3/8 adjustable pushrods ( these are not quick install, if you want a quick install type please specify at time of ordering)
We can also pre gap the rings for you, as well install your cams into your plate. The cost for fitting rings is $40 and $30 for cam install, If you do both we will discount that to $60 for both services. Please let us know how we can assist you, we are here to help and to ensure your build goes as smooth as possible. We do have ahead & cylinder exchange program please enquire.
$2,295.95 96 inch to 107 kit with gear drive cams * plus shipping
Old Jul 18, 2007 | 05:23 AM
PapaTravis's Avatar
PapaTravis
Murray, got another one for you. http://www.zippersperformance.com/
Old Jul 18, 2007 | 06:28 AM
Rocco18's Avatar
Rocco18
I don't know where you are but don't mess around and go right for the best ZIPPERS 107!!! As soon as I get the money I'm getting the 107 put in my 06 FLHT and also putting a 6 speed in there at the same time. Check it out!! The site is www.zippersperformance.comsee what you think.
RoadKingGibson
Exhaust System Topics
25
Nov 18, 2011 09:20 AM
donk_316
11
Mar 24, 2008 11:17 PM
lkr0
Oct 15, 2007 12:31 PM
Manish_Hawg
Oct 3, 2007 09:52 AM
zoomie67
Dec 11, 2006 03:47 PM
