6th gear disappeared!
Old Dec 18, 2019 | 08:48 PM
texasdw's Avatar
texasdw
Default 6th gear disappeared!
Poof! Just like that.
2019 Road King. 15,600 miles, bought new at the end of April '19. Been running just fine. This weekend I shifted into 6th and I felt a grinding sensation on my foot. Not subtle either. But the rest of the 200-mile trip it ran just fine. Today I got on the freeway, and when I shifted into 6th gear the engine revved up and the bike just started coasting. In 6th gear, there is absolutely NO power getting to the rear wheel. In 1st through 5th, it runs fine, sounds fine, pulls like it always has. But in 6th...nothing.
Obviously, it's still under warranty and I'll be taking it in this Saturday.
But in the meantime, just for kicks, diagnose my problem.
Old Dec 18, 2019 | 08:54 PM
memphisharley's Avatar
memphisharley
I'll take a stab at it. id say your 6th gear is gone
j/k...im wondering what it could be as tranny work is not too common on these bikes.
Old Dec 18, 2019 | 08:55 PM
05UltraBob's Avatar
05UltraBob
Had a friend this happened to with his 19 Triglide. It ended up needing the guts of the transmission replaced.
Old Dec 18, 2019 | 08:58 PM
Grouser62's Avatar
Grouser62
Have you been checking the transmission fluid level? I know squat about these things but I do know there is the transfer issue. A transmission with little or no fluid in it can't be happy.
Old Dec 18, 2019 | 09:02 PM
texasdw's Avatar
texasdw
I'm compulsive about maintenance, checking, and having service done at appropriate intervals. Always full synthetic oil too.
Old Dec 18, 2019 | 09:11 PM
btsom's Avatar
btsom
Nothing is free, YOU need to take some responsibility for trouble shooting. Are all external parts of the shifting mechanism properly attached and tight? Both front levers tight on he shaft, the front arm tight on the shaft. Both ball joints on the shift rod in reasonably good shape, and the REAR ARM TIGHT? The rear arm seems to be most prone to loosening and stripping of any of the other parts. Between 20 and 25 thousand miles is when shift rod ball joint failure starts to show up. Converting to Heim joints BEFORE the ball joints fail is a great improvement If all of that stuff is correct and tight, it is internal in the transmission, the shift pawl or 6th gear itself. Be happy you are still under warranty.
Old Dec 18, 2019 | 09:15 PM
TriGeezer's Avatar
TriGeezer
I’m gonna take a wild assed guess...sumpin wong. Take it to the dealer. You’re not a gear stomper are you?
Old Dec 18, 2019 | 09:20 PM
texasdw's Avatar
texasdw
Yikes! Nope. Not me. I have it in the shop every couple thousand miles for maintenance (I bought prepaid maintenance at the dealer when I bought the bike). I shouldn't have to crawl around and do this kind of work within 20K miles. More importantly, that is not my area of expertise. I can take people apart day in and day out, but when it comes to wrenching and mechanical stuff, I'll defer to the professionals in that area.
Old Dec 19, 2019 | 05:13 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Looking at the fische, it sorta looks like 6th sits on its own needle bearing set, which may be gone now. Possibly the dog isn't sliding over enough either, but that's less likely since you don't say anything bad about shifting into 5th, which is the other side of that dog and fork. Also interesting, there's no separate part number for 6th gear in the fische.
In any case, I suspect you're going to get your transmission replaced. Perhaps they'll do an internal change-out, but I'd suspect a complete unit swap is more likely.
Old Dec 19, 2019 | 06:07 AM
corliss@bakerdrivetrain.com's Avatar
I would have to agree this, or possibly the dog side of 6th may have sheered off, causing loss of 6th. I would be interested to know what you find.
