Switched to LEDs and shortly thereafter one of my signals is out (rear right). Its not the light itself as it works when swapping with the left. I admittedly know very little about electrical. I know I may need to just follow the wires and look for obvious things but before tearing things apart is there something I am missing? Something simple and obvious? I have not tried putting regular bulbs back on, if that would tell me anything that is...
If just bulbs, it`s time to get out your voltmeter, or buy one.....
this is essentially what I got...similar to these. Nothing else was done, just replaced these with the normal bulbs. I do have a voltmeter but wasnt sure where to begin. And for what its worth I replaced front and rear. All are fine except the right rear. Oh and the light works and comes on, just wont blink.
All four come on and the other three all blink. When I signal right the right rear simply doesnt blink. Still stays on, just doesnt blink. When I swap with another LED same thing. Its always the right rear regardless of witch bulb is there.
i put in the regular bulb. With right signal on front blinks and rear does not. Light is on; but does not blink. So its the same with either bulb. Also note the brake light does not work either. Left side does, but when applying the brake the right rear just stays the same...on but does not get brighter.
