2013 Electra Glide Classic QUICK RELEASE
Old Jan 10, 2020 | 10:23 PM
bulldog82098's Avatar
bulldog82098
Default 2013 Electra Glide Classic QUICK RELEASE
What do I need to make the tour pak on a 2013 FLHTC quick release. I don't believe it has any wiring etc. running to it?
Old Jan 11, 2020 | 07:11 AM
richardgalbraith68's Avatar
richardgalbraith68
I bought a used 2012 FLHTCU and it was already set up for quick release tour pack. My tour pack had the wiring to it, antennas, lights,and speakers. You would need to purchase the quick disconnect kit from HD. If there isn't wiring going to your tour pack, should be easy.
Old Jan 13, 2020 | 09:57 PM
rickb's Avatar
rickb
My 13 Classic has wiring in it and an antenna so you will have to deal with both.
Old Jan 14, 2020 | 07:51 AM
Jed Clampett's Avatar
Jed Clampett
Quick detach docking kit, detachable tour pak rack. Remove solid mount rack. You can get an antennae that can mount inside of fairing from aftermarket. Easy peasy.
Old Jan 14, 2020 | 10:07 AM
Fetasigma's Avatar
Fetasigma
dont do the antenna that mounts inside the fairing unless you just listen to radio in town, out here in the country they dont work if your in the middle of nowhere, a longer antenna mounted by the bags does the trick. personally i listen to music from my phone anymore so it doesnt matter anymore but that was my experience.
Old Jan 14, 2020 | 12:21 PM
miner999r's Avatar
miner999r
Me i would just go the antennae relocation. For as often as I would take off the tour pack I can live with undoing 4 bolts and disconnecting the wiring connector. Only disadvantage I can see is I would have to take the stuff out of the tour pack for one or two times a year I might want to do this change.
If you are going to do the swap a lot and / or use different configurations then maybe worth the cost.
desertwolf
Milwaukee Eight (M8)
Nov 9, 2019 07:01 AM
Matthew E. Dordal
Sep 17, 2015 09:34 AM
99ultra
Nov 4, 2012 08:19 PM
Mental
Aug 27, 2009 05:15 AM
msh134
Dec 6, 2008 10:53 PM
