Helmet buffeting...possible solution???
Old Jul 18, 2007 | 02:27 PM
TampaJim's Avatar
TampaJim
Default RE: Helmet buffeting...possible solution???
Don't waste your money on that micro swirl edging. I got it a while back and it did nothing. Plus it's ugly and puts a big black rubber line through your line of vision. I know some sport bike guys who swear by it, but just does not seem to work on cruisers.
Old Jul 18, 2007 | 02:41 PM
SteelCityScooter's Avatar
SteelCityScooter
I wasn't getting the buffetting, butI was getting ashes from the smokes in my face while riding.
Three Bolts, some blue permetex, and ten minutes
Chrome Front Fork Air Baffle
Deflect the cold night wind rushing between the fork tubes of your Touring model. This stylish chrome air baffle replaces the Original Equipment black baffle on '00-earlier models. Includes chrome mounting hardware.
58520-79TC
Fits '80-later FLT/FLHT/FLHX/FLHR models.
MSRP US $22.95
And most of the time I ride with a ballcap and I don't wear aballcaps backwards.
At 70 on the highway ballcap rides just fine.
Old Jul 18, 2007 | 02:47 PM
SteelCityScooter
ORIGINAL: RangeRat
Anyone know yet if it helps (or hurts)heat stuff with an'07 FLHR? It might actually help if it re-directs air flow down over the fins.
Harley installed those deflectors stock in Black up until 02 or 03, but then stopped, and put out a notice to remove them if you were experiancing heat problems.
I have had mine on the 06 Ultra since last summer, and it has not caused any extra heat, or reduced it any that I can tell.
But it did stop the air over the tank that then runs up the front of your torso.
Old Jul 18, 2007 | 03:18 PM
FLHT's Avatar
FLHT
I'm telling you guys that are getting the buffeting, For 20 bucks throw that fork baffle on, you will be surprised how much it helps.[sm=closed.gif]
Old Jul 18, 2007 | 05:56 PM
rickoshay45's Avatar
rickoshay45
I put the fork baffle on mine and love it. I had several issues. Too tall windshield ( fastaire 8" solved that). Glasses and helmet bouncing up and down. The fork baffle solved that. As I said earlier if you take your left hand and put it near the front of the tank at cruising speeds you will feel a lot of wind.
There seems to be no single answer to the problem. Just deal with the sources one by one. The air baffle is cheap and cannot hurt the engine temp problem. It might improve it, but no way to tell. It's cheap and worth a try.
Windshield height is another problem. Many say the windshiled should just reach to the tip of your nose. You can cut your shield down, or do like me and buy a Fastaire for $25 and try it.
Old Jul 18, 2007 | 06:15 PM
PhilM's Avatar
PhilM
Simple test....
Try removing the visor from your helmet.
Old Jul 18, 2007 | 06:25 PM
Doc's Avatar
Doc
Listen to FLHT
From many posts long ago, I put a fastaire (tinted with recurve) 8" and a baffle on my 07 Ultra.
The baffle does the most. The fastaire I use for around town and the 12" for trips.
Old Jul 18, 2007 | 06:47 PM
Mathews2's Avatar
Mathews2
ORIGINAL: PhilM
Simple test....
I removed the visor, Best thing I did for riding comfort. And the cheapest mod ever made [8D]
Old Jul 18, 2007 | 06:57 PM
RangeRat's Avatar
RangeRat
ORIGINAL: SteelCityScooter
ORIGINAL: RangeRat
Thanks for the info SteelCityScooter.
Steve
Ryan David
Mar 16, 2021 03:49 PM
9one1
2014-2024 Touring Models
23
Mar 22, 2014 07:44 PM
glenn473
Aug 16, 2011 10:19 PM
floridian46
Mar 26, 2007 11:18 AM
billk
Sep 7, 2006 12:30 AM
