07 Road king
Old Feb 3, 2020 | 03:15 PM
Jason Double's Avatar
Jason Double
Default 07 Road king
Hope I got the right forum this time,, anyways Road king police special about 3 months ago I parked bike at a drink stop jumped on an hour or so later and not start,, the only thing I did different was not stop in nuteral,, gave the starter a bit of tap and seemed to go OK,, have tried this several times now, and same result,, any ideas,? Is this likely to get worse over time?
Thanks for answers in advance guts and girls
Old Feb 3, 2020 | 06:00 PM
Zerk's Avatar
Zerk
So you tapped on starter and it started? It's not going to fix itself
I would make sure cable is tight. Probably replace starter clutch if not loose. Best case is start trouble shooting with meter when it doesn't start.
nice thing with 07 is don't have to open primary to change starter. I use long Allen socket and pull them both from right side. Though I got 2-1 exhaust.
Old Feb 3, 2020 | 06:14 PM
MURPHCC1's Avatar
MURPHCC1
Any sound trying to start or nothing?
Check cables, tight, not burnt
Old Feb 3, 2020 | 06:22 PM
J2X's Avatar
J2X
You probably want to replace that starter. I have an 07 RKC and I am sure things will need replacing. Just replaced the brake pressure switch.
Old Feb 3, 2020 | 06:53 PM
eighteight's Avatar
eighteight
starter relay contacts & connections are easy and inexpensive first checks
Old Feb 3, 2020 | 08:55 PM
Zerk's Avatar
Zerk
What I love about these threads is lack if help from the guy who started it.
since the guy didn't tap on starter relay, not where I would start, unless I had a meter in my hand.
Old Feb 4, 2020 | 07:29 AM
eighteight's Avatar
eighteight
You are correct, I should have said contacts in the solenoid
Old Feb 4, 2020 | 07:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you don`t have a clue about the subject, don`t give advice.
Jason Double: Don`t even think about replacing the starter.
But do give us a better description of what the problem is, your original post is not clear.
Old Feb 4, 2020 | 08:08 AM
Vernal's Avatar
Vernal
Watch this video and listen to Doc Harley.
Old Feb 4, 2020 | 11:01 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Nipondenso starter is famous for burning the contacts and plunger. Little awkward getting in there, to replace them. But many times just cleaning them will take care of it.
