This is home. I'll ask here
Old Feb 16, 2020 | 06:49 PM
WP50's Avatar
WP50
Default This is home. I'll ask here
Got an 08 UC that has an intermittent charging problem.
In the oem manual they refer to the ground for the -neg side of the voltage reg goes to a Left Dirty GND ( ground).
I got it ck'd out with some good ol digging around .
But if someone knows what the H^%& they are referring to I'd like to know.
Thanks folks WP
Old Feb 16, 2020 | 07:08 PM
Bass Player's Avatar
Bass Player
Check all grounds, battery to frame and your positives as well. Voltage regulator is supposed to be "cleanly" grounded to the frame as well. I took mine off and cleaned where it bolted to the frame. It cleared an intermittent problem like you are having. PO had put a new one on and only finger tightened it. Mine is an older bike and and one leg bolted to my relay, check all those as well.
Look at the bottom side of of your VR and make sure it isn't cracked. If after doing the easy stuff it still happens then you need to make a determination if the problem is the VR or the stator.
Old Feb 16, 2020 | 07:26 PM
WP50's Avatar
WP50
Would you please elaborate on this. It's mount or body ???
Any idea what the dirty ground is referring too??
WP
Old Feb 16, 2020 | 09:10 PM
Ragtop's Avatar
Ragtop
https://www.hdforums.com/forum/ignit...round-wtf.html
Old Feb 17, 2020 | 07:23 AM
WP50's Avatar
WP50
Thank you very much Sir
WP
86glider
EVO
May 25, 2019 08:41 AM
Hawgnuttz
Electrical/Lighting/Alarm
Jul 5, 2018 03:20 PM
Spookers
Jun 29, 2018 08:42 AM
soft 02
Oct 18, 2011 08:20 PM
Keener
Sep 24, 2008 08:10 PM
