Hooking up accessories directly
Old Jul 21, 2007 | 11:02 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Default RE: Hooking up accessories directly
ORIGINAL: SFarace20
Thanks Texas!! I did use it and it worked perfectly. I made it part of the line and it worked. I read several posts where they said they just hooked it up directly... I can't figure it out... they must have12v receivers, I guess. My next project it to hook upa GPS to the ACC switch connection under the seat. I noticed that the connection (under the seat) has 4 wires and the power out of the GPS only has 2 (cigarette lighter power)... any ideas. I have purchased the parts to make the female connectors to plug into the "Y" connection under the seat (ACC outlet)..
Thanks again, you have been a tremendous help.
The Sirius reciever is 12 volt
Old Jul 21, 2007 | 11:21 PM
gman's Avatar
gman
ORIGINAL: IAMSWUTIAMS
ORIGINAL: SFarace20
NOT TRUE. Some may be, but the Starmate 4 I bought recently has a small transformer built into the cigarette power cord. 12v into the cord, but only about 4.5 volts actually to the radio. 12v will fry the radio. before you automatically put 12v to the radio, check out the supplied power cord to ensure it isn't stepping down the voltage.
Old Jul 22, 2007 | 12:06 AM
SFarace20's Avatar
SFarace20
This has sure been a learning experience. I am amazed at how much information was available on this topic, and how different the information is. I also appreciate everybody contributing. I am mechanically skilled, however, when it comes to electronics I am a novice. My Sirius Receiver is not a 12v unit, it is 4.5. I did hook it up directly (12v) and it did not fry, or blow any fuses, it just would not go on. Then I hooked it up from the same power source (the additional light hookups for international models) through the cigarette lighter adapter and it worked. I tightened, taped, and tidyed everything up, tucked it under the fairing, double checked that everything still workedand called it a day!!!
Old Jul 22, 2007 | 07:03 AM
TexasRedneck's Avatar
TexasRedneck
Like with anything else, sometimes ya gotta double-check stuff. Can't count the number of times over the years I "presumed" that something was one way, and found it to be different!
Old Jul 22, 2007 | 04:47 PM
swipter's Avatar
swipter
Well I read this thing three times and am still baffled. If I ever want to do this, which I was thinking about, I will offer lunch for the help.
Old Jul 23, 2007 | 07:53 AM
TexasRedneck
Anytime, mah friend........you ride w/Gruene HOG??
Old Jul 23, 2007 | 08:02 AM
glens's Avatar
glens
Well, technically it can't be a transformer since they don't work with direct current. "Voltage divider" would be a better term.
Old Jul 23, 2007 | 12:47 PM
swipter's Avatar
swipter
ORIGINAL: TexasRedneck
I was thinking about riding with Gruene hog. Cowboys is a little far.
hoakken
Audio Systems
Oct 9, 2016 01:50 PM
hdultra2007
Feb 18, 2015 03:06 PM
CVO-RK
Audio Systems
11
Apr 22, 2013 09:26 AM
tjdlsj
Audio Systems
Jan 9, 2012 08:57 AM
Wanna Ride
Aug 4, 2010 12:17 AM
