FP3 or Something different?
Old Apr 14, 2020 | 06:14 PM
Aobaker2001's Avatar
Aobaker2001
1st Gear
Default FP3 or Something different?
I would like to get some opinions on what fuel pack to run. FP3 appeals to me because it will not require a dyno. Opinions are welcome for others but I would like to know the “why.” Thanks in advance!!
Old Apr 14, 2020 | 06:44 PM
todd-67's Avatar
todd-67
Power vision from fuel moto. Good base maps and if you want to get it tuned or build the motor later on it will support it.
Old Apr 14, 2020 | 07:03 PM
SWMB's Avatar
SWMB
Just my experience the FP3 worked excellent with a Stage 1 but if your going past that get a better Tuner. That is unless you can find a Dyno operator that will tune with the FP3.
Old Apr 14, 2020 | 07:39 PM
MyFavRk's Avatar
MyFavRk
I use the FP3 , have for the past couple of years . It's an awesome little gadget if you only do a stage 1 . They do have maps for stage 2 set ups as well , but I have no opinion on it yet , have a set of 48H cams sitting on my bench waiting to go in , so will see .
The power vision will do everything you need , including all the stage set ups . Seems to be the top choice here .
Old Apr 14, 2020 | 08:37 PM
grinner's Avatar
grinner
Not sure why people keep saying FP3 is primary just a stock or Stage 1 tuner. That might be a holdover from previous iterations of the FP3. I have a cam in my 2019 Electra Glide with aftermarket mufflers. A V&H tech created a custom map for me in about 5 minutes and it absolutely slays.
I'm in WI, the same state as Fuel Moto. On a previous bike I had them do a Stage 1 with Powervision and a dyno in their shop. That was great, too.
You can go either route and get great results, but you'll have more end-user configuration available with the FP3. Throttle progressivity, etc. I've had the FP3 on two bikes now and I've been thrilled with it.
Old Apr 14, 2020 | 09:02 PM
SWMB's Avatar
SWMB
Yes I've also had the FP3 on 2 different bikes with the second 1 a custom tune from V&H and they likely can work on a stage 2 but never worked for me with a S&S 475 cam.
Old Apr 15, 2020 | 11:59 AM
23Seven's Avatar
23Seven
Get those 48’s installed and wake up the beast!
Old Apr 15, 2020 | 02:11 PM
twincam10353's Avatar
twincam10353
Most responses you will get here will be along the lines of FP3 if you are only going to Stage 1.
Old Apr 15, 2020 | 05:08 PM
30glock's Avatar
30glock
I am also confused by this, stage 3 here with no issue, thing is a beast.
Old Apr 15, 2020 | 05:15 PM
MyFavRk's Avatar
MyFavRk
Well , I gotta say that I'm feeling reassured now , knowing that it's working fine for others . There are a lot of threads on this topic , more or less saying it's rather difficult to get a good tune . I guess it's a matter of getting the right map to begin with , just have to get the proper tools to put my cams in and see what happens .
