...easier clutch pull.......
Old Apr 18, 2020 | 08:01 PM
not a sock's Avatar
not a sock
Default ...easier clutch pull.......
......for my '16 Street Glide Special?
I have the AIM on my '18 FLHTCU and it is GREAT!
However, the clutch pull on the Street Glide is hard on my
ol' broken hand.
Anyone know of something to do to this clutch to make it easier?
Old Apr 18, 2020 | 08:02 PM
dawg's Avatar
dawg
Muller makes a nice replacement actuator slave that will work on your 16. https://www.denniskirk.com/muller-mo...prd/385849.sku I have the Muller 120-60 in my 19 and love it.
Old Apr 18, 2020 | 08:19 PM
pyuchem's Avatar
pyuchem
I have AIM VP95LT-Invo on my 2016 street glide. It works ok but I’m not happy. Have done some research and will buy Müller hydro clutch. Looks like for 2016 we need unit that says 120-50. I posted this same question few days ago and lot of seems lot of folks here like their Müller hydro clutch. I’m looking forward to getting it put on.
Old Apr 18, 2020 | 09:09 PM
not a sock's Avatar
not a sock
Thanks.
So much for the search function.............
Old Apr 18, 2020 | 09:47 PM
hattitude's Avatar
hattitude
2016 Ultra Classic with AIM VP and Barnett heavy duty spring... the Muller Hydro Clutch actuator made a big difference for me...
FYI.. AIM also makes an actuator, that actually gives a slightly lighter pull than the Muller. From what I've read, the Muller is like 30% easier then OEM and the AIM is like 40% lighter than OEM...... however, their slave is made for an M8, which uses a different master cylinder and different hose fitting... To use the AIM, you'll need to buy there "kit" which includes a master cylinder, hose fitting adapter, and about $200 more than the Muller..
https://aim-tamachi.com/collections/...29230444609559
Old Apr 19, 2020 | 04:34 AM
23Seven's Avatar
23Seven
I guess no one would want to mess with my stock clutch with SE spring... I’m use to it and don’t even notice it anymore.
Old Apr 19, 2020 | 08:36 AM
Oko's Avatar
Oko
FWIW - I found my OEM clutch pull horrid when in stop & go or parade riding. Hell, when I picked up my '16 FLHTK, I got stuck in bumper to bumper traffic on the Cross Bronx Expressway for an hour. My carpal tunnel was on FIRE!
So my first move was the SoftBrake reduced reach levers. That, (to me), made the clutch feel 30% easier. Still a bit tough in parade riding, but way better.
Now, with my 110" build, I've got the AIM and the EZ Pull.
If I hadn't bit on the 110" build, the EZ Pull by itself, was my next move.
Now, with all three items, my HD clutch is as light as my 1999 Honda metric cruiser.
And that's with a heavier clutch spring installed.
Old Apr 20, 2020 | 05:44 PM
EdandGrace's Avatar
EdandGrace
On install, when removing the fluid line, does it drain all clutch fluid or just bleed a little?
Old Apr 20, 2020 | 06:16 PM
rock92's Avatar
rock92
a good amount comes out. you will need to be prepared to have some to refill and bleed the line. also cover parts in that area so they don't get the fluid on them and something underneath to catch what does come out.
Old Apr 24, 2020 | 05:53 PM
EdandGrace's Avatar
EdandGrace
Installed today and bled the line with a mity vac. Clutch felt good but after I put into gear it was engaged even with the clutch pulled in. Able to find neutral with no problem. Bleed again or what?
