2018 Road King, I had to swap out the riser bushings and install a 1 piece clamp... I only unplugged the headlight to do this, nothing else.. I taped the bars to the windshield to keep them in place while I was making the change.
Got it back together, started fine and idles, but throttle is unresponsive. Pretty sure I probably pulled something loose maneuvering the wiring around the new 1 piece clamp, so I'm going to pull it apart again today and check everything. I've done bars a dozen times, though, and this never happened.
I might have exacerbated an existing problem, I've a check engine light on for a while and the bike wouldn't start if bars were turned all the way to the right (which tells me issue is on throttle side) . Took a hard fall during practice and then that started.
thought I'd ask if there's something I haven't thought of. Gonna check plug at the throttle
body, the TGS lines (there's no green plug) and mostly focusing on where the wires exit the bars, as thats what I was messing with yesterday.
Seems like you’re on the right track. I’d also suggest that since you’ve had the CEL when bars turned, pull the codes and it might give you a sense of where to look.
I had same thing happen after installing cruise control on 2017 Fat Boy. The plug for TBW had backed out just enough under the tank that it had no response.
Seems like youre on the right track. Id also suggest that since youve had the CEL when bars turned, pull the codes and it might give you a sense of where to look.
yeah, I'm throwing a ton. pretty sure it's a loose plug from the TGS
P0107 Map Sensor Low/Open
P0651 5 volt reference 2 out of range
P2138 TGS Correlation error
P2122 TGS 1 low/open
P2127 TGS 2 low/open
P1510 EFI limited performance mode
P1512 EFI forced idle mode
U0142 (this was already there with previous issue) lost comm w RHCM
