2009 Flhx
so the other day as Im riding .. I notice my oil temp gauge started to fluctuate.. and then a while later its the oil pressure gauge and then after that its a volt gauge ... it does not affect the speedometer does not affect the tachometer or the fuel gauge.. Im guessing its a grounding issue would I be wrong has anybody else had this problem? I never get a battery light or a oil pressure light .. Everything works fine bike runs fine lights dont Flickr or flash ??
Just very strange any thoughts would be appreciated thank you
yeah I remove the air temp gauge put in an oil temp gauge maybe Ill just remove all the gauges if I cant get it fixed hell my Dyna dont have a gauges and it seems just fine.. just annoying to look down at the gauges and see them jumping around
Might be a bad ground. Check battery connections first and then your ground, then your leads. Gauges work on micro- milliamps and often a bad ground makes the gauges jump.
