Valve to Piston Clearance
Old Apr 29, 2020 | 07:00 AM
skydude426's Avatar
skydude426
Default Valve to Piston Clearance
What is the minimum valve to piston clearance when building a twin cam engine? I had oiling problems with my previous 107” big bore engine and I’m currently rebuilding it. I don’t anticipate a valve to piston clearance problem but I’m checking everything as I go to make sure it’s right so I plan on using clay to check the valve to piston clearance. I haven’t found much about this on line. What I have found is older and I’m not sure if it applies to a 103” to 107” big bore. Thanks in advance for anyone who builds engines and knows what this spec should be for minimum safe clearance.
Old Apr 29, 2020 | 07:41 AM
hellonewman's Avatar
hellonewman
Rule of thumb on any engine is .100" on the exhaust valve, yes some run .080" but more is better. Intake can be less as its not trying to outrun the approaching piston like an exhaust valve is. You also need to check radial clearance and the best way is the playdough method. Put a little bit of oil on the valve faces so it doesn't stick to the valve and pull it off the piston ruining the test.
Old Apr 29, 2020 | 09:08 AM
skydude426's Avatar
skydude426
What I found so far on line was .09” on the exhaust and .06” on the intake. I think this particular article was referring to an evo engine so I wasn’t sure if these measurements apply to a twin cam.
Old Apr 29, 2020 | 11:00 AM
hellonewman
The reason for the .100” is to account for some valve float. I’ve run as much as .160” on some applications knowing the guy might miss a shift. Doesn’t matter evo, Honda, Indian or Lamborghini. .100” is safe, so is .090” but I wouldn’t go less.
Old Apr 30, 2020 | 05:25 AM
skydude426's Avatar
skydude426
Hellonewman, I found a couple more sources that were talking about non Harley specific motorcycle engines. They both suggested .1” for the exhaust and .08” for the intake also. Sounds like good safe clearances. I guess if I were pushing those numbers by .01” I would go with it but not anymore. I’ll find out where I’m at this weekend. They also said to stick with a minimum of .05” side clearance in the valve cut out. Thanks for your reply’s.
Old May 2, 2020 | 05:45 PM
skydude426's Avatar
skydude426
Ok. I used clay to check my front cylinder and thought I’d post my results as this will be available on line for others to see. I guess I didn’t need to worry about clearances. I didn’t figure I did but I wasn’t expecting what I found. There were no marks at all in the clay meaning the valves didn’t even reach the valve cut out in the piston. I put clay around the half moon valve relief and used a razor blade to cut it level with the piston top. Here’s what the build is.
-107” cylinders with a deck height of .027”
-pistons with a 3cc dome
-.030” head gasket
-ported heads decked to 84cc
-1.9” I take valves
-1.610” exhaust valves
- Red Shift 575 cams .575” lift
al0311
EVO
Jan 25, 2020 02:38 PM
EvilWayz
Ironhead
11
Sep 21, 2017 08:39 PM
2009FLSTSB
Apr 28, 2015 07:44 PM
jurgie
Exhaust System Topics
Apr 22, 2013 05:51 AM
Stng72
Sep 6, 2010 09:53 PM
