Charging at 11..new rectifier
Old May 10, 2020 | 06:11 PM
Freddie pruitt Dobbs's Avatar
2nd Gear
Default Charging at 11..new rectifier
Does this mean stator is out
Old May 10, 2020 | 07:48 PM
Rustyg500's Avatar
Rustyg500
maybe
Old May 10, 2020 | 08:03 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
So the new voltage reg./rectifier is putting out 11 volts? You could do the test for stator shorting out pin to pin, pin to ground. or a quick non scientific is the smell test, take the derby cover off, if there is a burnt smell, the stator is toast.
Old May 11, 2020 | 08:20 AM
grbrown's Avatar
grbrown
In the Tech Electrical section there are instructions on testing and diagnosing your charging system. Use that to identify the cause of your problem.
Old May 11, 2020 | 11:56 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
No, it means that your charging system is not charging...maybe.
To find the cause you can continue guessing, and buying parts....
Or, you can troubleshoot.
You might mention what the problem is, etc.
And, Model and Year of bike.
aces&8s
Dec 26, 2018 09:03 AM
96RK
Dec 18, 2011 06:24 PM
byronrub
Jun 10, 2009 12:07 PM
3littlepigs
Jun 2, 2008 01:09 AM
gsparesa
Nov 14, 2005 01:29 AM
