Apple Car play
Old May 14, 2020 | 08:46 AM
jeffdag's Avatar
jeffdag
Default Apple Car play
I have a 2020 with the GTS Infotainment system. I have followed the directions below to set-up Car play from the manual, but no icon shows up. Phone does connect, because the display shows no media message. Any suggestions?
Apple CarPlay does not require an app download. When connected, not all iPhone apps will be displayed on the screen, only Apple approved apps.
The rider requires a headset with microphone to enable voice commands. 1. Switch power to Accessory, Ignition or Run (CVO).
2. Turn projection mode on.
a. Navigate: Home > Setup.
b. Select: Projection Mode ON.
3. Connect: Cord between phone and USB port on vehicle. The CarPlay icon replaces phone icon on the home page.
4. See Figure 1. Select: CarPlay.
5. See Figure 2. Apple CarPlay is now visible on the radio screen.
Old May 14, 2020 | 08:51 AM
coop creek's Avatar
coop creek
is your head set turned on?
Old May 14, 2020 | 08:59 AM
coop creek's Avatar
coop creek
Also, when you turn on the headset, it should say "connected to boom box" or something like that. Make sure the headset isn't connected to your phone?
Old May 14, 2020 | 09:27 AM
arampgds's Avatar
arampgds
3rd Gear
Has the GTS Infotainment system been flashed to allow carplay? I have a 2020 RGS, it had to be flashed for carplay.
Old May 14, 2020 | 11:06 AM
skratch's Avatar
skratch
is your gts straight off the showroom floor? or did you have a whim installed? if you don't have the whim, or have your bike flashed for the whim (with mic disabled), you will not get apple CarPlay.
Old May 14, 2020 | 03:26 PM
jeffdag's Avatar
jeffdag
So it sound like I have to have a headset plugged in, but that did not work. I as going to ask about the flashing at my next service. Thanks All.
Old May 14, 2020 | 04:17 PM
skratch's Avatar
skratch
you didn't answer my question, do you have the whim installed?
sometimes, CarPlay is finicky. my wife will have problems with CarPlay coming up, even when she has turned her headset on first. when that happens, she has to go into her settings, pull up wireless headset settings, manage rider, and then it'll show her headset as 'idle'. she will 'forget' it at that point, and go through the pairing procedure. when it pairs, it will allow CarPlay to initialize.
Old May 15, 2020 | 06:28 AM
krabun's Avatar
krabun
The key to your issue is getting the WHIM Enabled setting turned on via the Digital Technician system at your dealership. A headset is NOT required to get CarPlay audio output functionality (music, navigation prompts, text message output) working at your fairing speakers. A headset IS required to be able to listen to audio with speakers in your helmet, use SIRI voice commands, send/receive phone calls and record/send text messages, etc. A WHIM with connected HD brand SENA wireless headset simply allows all the same functionality of a HD corded headset to occur without the wires.
Old May 16, 2020 | 08:35 AM
jeffdag's Avatar
jeffdag
So sorry. No WHIM installed. I would have expected car play to work as it does in every other car or truck. Simply plug it in and the apple icons appear. It should not be so convoluted. Thanks!
Old May 16, 2020 | 08:37 AM
jeffdag's Avatar
jeffdag
No WHIM installed. So Car play does not work unless you install the WHIM module? I would expect to simply plug in the iPhone and Car play would vitiate and show the apple icons as it does with every other car or truck. Why would HD be any different. Thanks!
