Disconnect O ring or worse?
Old Jun 4, 2020 | 09:47 PM
glsec507's Avatar
glsec507
Default Disconnect O ring or worse?
2011 FLHTCU
I've tried searching but all I get are people talking about the fuel leaking from the disconnect while it's connected. Today when removing the tank for other upgrades I discovered that my quick disconnect leaks after I disconnect the lower line. If I reconnect it the leak stops.
O ring issue or do I need to replace the valve? Any tips for both? What to get and where? How to remove etc...
Thank you!
Old Jun 4, 2020 | 09:53 PM
handirifle's Avatar
handirifle
I am sure someone who knows will chime in soon.
Old Jun 4, 2020 | 11:42 PM
Shanebo's Avatar
Shanebo
https://www.harley-davidsonforums.co...cement.336185/
There are three o-rings in the valve all together.
Not a bad job, just need to get the right o-rings.
Another thread link: https://www.hdforums.com/forum/ignit...2-softail.html
All the best,
Shane
Old Jun 5, 2020 | 06:59 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Another thread that might help you out.
https://www.hdforums.com/forum/touri...l-fitting.html
Old Jun 5, 2020 | 07:02 AM
glsec507's Avatar
glsec507
Thanks guys. I have seen these. I guess I wasn't sure if the issue was the same if it leaks when disconnected. I'll try the O ring route. Hopefully.
Old Jun 5, 2020 | 09:00 AM
Boomer1143's Avatar
Boomer1143
This is a set of O-rings the correct size for resealing the quick connector. I've installed several and they work well.
https://www.ebay.com/itm/Harley-Davi...53.m1438.l2649
Old Jun 5, 2020 | 09:03 AM
glsec507's Avatar
glsec507
I think I found the issue. Now that it is day light I can see inside the female side of the disconnect better and it appears the O ring at the end (tank side) is not seated all the way. I used a small screw driver to push on it the whole way around and as of now I do not believe it is leaking anymore. I had to siphon out gas last night so I don't have much in there to really test it but I will soon.
cjgray
Aug 28, 2024 12:34 PM
giarcmo
Feb 20, 2023 08:15 PM
beemer737
Exhaust System Topics
Aug 25, 2010 05:53 PM
navarrjs
Aug 17, 2008 05:14 PM
bigstevex4
Jul 25, 2008 10:06 PM
