Not true anymore. The newest NOCO 40 has clamps with a thinner width. (probably redesigned when they labeled a 40 for sale by HD). Now both have the same size clamps and easily fit the starter solenoid bolt.
Good to know. When I purchased my GB40 about a year ago it came with big *** clamps. I ended up ordering the clamps for the GB20 Sport, which are the same size as the Hog Booster's.
I have the NOCO GB70, would that cable work for me?
It's not listed on the amazon webpage as GB70 compatible, but the connectors look to be the same?
I have asked this on the Amazon link to the product also on the NOCO support page, still no answer.
IF the connectors are the same it should work right? I just would like to know before I order it.
The specs say "Compatible with NOCO Boost UltraSafe Lithium Jump Starter models GB20, GB40, and GB50 and any battery charger with an SAE connector. The GB70 looks the same as the GB50 as far as the connectors go.
Thanks
Thanks
The GB20, GB40, and GB50 have a single connector for both battery clamps on the end of the unit. The CBC 009 connects to that after removing the clamp connector. How are the battery clamps connected to the GB70? It looks like one on each side?
Yes, they are hardwired into the unit though. That's why the GBC009 cable won't work on the GB70..
Bummer for me, I might just buy a GB50 as a spare to use on the bike so I can use the GBC009...
