Handlebar polyurethane bushing replacement w/fairing
Thanks!
remove the key in an UNLOCKED position so you can move the bars
remove the cover, put it aside
un-fasten 50% of one side, turn bars, remove the other side's screw... replace the rubber, fasten 50%, move to the other side, remove screw, replace rubber, fasten 100%, go to the other side, fasten 100%... you get the idea. just dont remove both screws holding the riser at the same time as that could cause damage.
-Put the new poly bushings in the freezer for a few hours or even a day before you install them.
-Use a silicon lube on the inside and outside of the bushings to get them in the bore of the top triple tree and also to help install the metal sleeves which can be super tight.
-Keep the handlebars bolted to the risers and just tip or move them back toward the tank (with it covered with a blanket of course), this will save you the headache of having to align the bottom risers as you put the riser bolt back in. Removing and/or tipping the inner fairing back helps the handlebars and risers clear everything to be able to maneuver the top bushings in and also the metal sleeves.
-Dont forger the red loctite on the riser bolts
-Cant remember what year youre working on, but my 07 had a small washer on the right side between the riser and stock metal washer on top of the top bushing to even things out as the left side has the ground washer between the bottom riser and top bushing.
-Getting everything back together is much more difficult than getting it out. I ended up having to start each set of bushings and inner metal sleeve with a dead blow and large C clamp and finish seating the lower bushing as I torqued the bolt to the final tightness, iirc 35 ft lbs.
HTH
- do the right side first (loosen left to 50% then do the right)
- before going back to the left, screw the right side all the way in, then loosen back to 50%. if the bushing is not completely inside the effing handlebar wont turn... haha
- to make the treads engage, it is necessary to push the bars to the front and to the top... be *very* patient those threads are a dog to engage with everything attached.
- to fit the bushing in... the easiest way I could find is to put the sleeve in, then fit that from the bottom... then do the top one while holding the bottom in place as best as u can - then you can use the riser as leverage to squeeze the ****er in.
and wow... night and day difference.much tighter! - hated the way my bars shaked @ idle, that is 90% gone! money well spent.
