Get bike on lift, and get engine alignment tool on rear swing arm so you have the swing arm in line with the frame center line, then check rear tire axle to front of swing are pivot distances.
Get frame level with alignment tool still on bike, the get string line down the front and rear tires to get the front tire aligned with the rear tire that is aligned with the frame, then put an angle gauge on both the front rotor and the back rotors, and make sure both front and back rotors at reading 90 degrees on the money.
If front rotor is not reading 90 with it straight down the frame line, then you have a problem with either bent fork, head tube not welded true, or triple clamp is bent instead.
On the back end, it's a frame thing, and just need to use the motor top turnbuckle once you remove the alignment tool to get the rear tire/ swiing arm 90 to the frame (leave the front turn buckle alone, since the alignment tool already set that correctly to begin with).
As for the whole level the frame, then angle gauge on the front tire to get it to 90 for string line use, does not tell you if the front wheel is actual pointing down the frame center line to begin with or not. And if not, then your going to be pulling the rear end way the hell out of frame center line to get it on the same line as the front tire isntead.
From here, check all your brake calipers to make sure that they are kicking back freely, and not bound up to hold the pads tight to one side of the rotor.
Note, do not use a petroleum base grease on the brake parts, since it will swell the rubber parts up on them to cause the caliber/pistons/guide rods to bind.
Thank you for the great info. I need to do more research to understand the details.
An absolute WILD GUESS. How many miles on your tires? If the roads where you ride are crowned, the flat area in the center of the tread will be a bit more worn on the left side. Turning to the right requires over powering the slight shoulder on the right side of the flat area but the left turn has less of a shoulder to overcome. Never noticed any difference on my bikes, just use whatever "muscle" is needed for the desired results.
OK, here's what I'm talking about. I'm going down the road , say 75 or 80, I have the same amount of beer in each bag. I come to a left sweeper and I just have to think about the turn and around she goes. Then down the road a little ways a right sweeper, but on this one I have to give the right bar a little more push. not much, but more than the left.
Architect is the only one close - unless the front mount stabilizer is cranked way out, the rear tire is out of line - period.
Doesn't matter about difference in saddlebag weights and for a cable be causing any such issue, it'd have to be too tight to let the thing steer when sitting still.
Too may people try to align the rear tire by getting the belt to run dead center of rear pulley. That seldom works out well.
