Oil change question
Old Aug 10, 2020 | 05:54 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I would STRONGLY advise you to use a bike oil, which has a higher Zinc content for less wear
I have gotten away from the synthetics in my motor, and am back into the Valvoline oils (VR1) in my bikes due to the high zinc content, and they do not thin down to nothing when they get hot. But I change my engine oil every 3000 miles, the other 2 holes are every 6K
I am still using Bel-Ray or quality synth in the other holes.
as for K&N, I have never heard anyone say anything bad about them, when in doubt check out the BoB Is The Oil Guy website he has tested them all
Old Aug 10, 2020 | 06:21 PM
skratch's Avatar
skratch
Originally Posted by handirifle
That was my intended use, thanks. I see the other parts are every 10k so not as concerned just yet.
even though the primary oil is spec-ed to change at 10k, i always do it at the same time as the engine oil. the primary gets really dirty, really fast, and does not take a whole lot of oil, so no biggie to change it. on my older bike, i would go ahead and do the clutch adjustment at the same time, but with hydraulic clutch, no adjustment.
if you're picking up the 15w-50 from walmart, go ahead and grab some shell rotella t 15w-40. around $12 for a gallon jug. it is jaso rated for wet clutch use so won't cause your clutch to slip.
the transmission is spec-ed at 20k for the change, not 10k. for that i would use supertech gear oil, fully synthetic 75w-140. also from walmart. about $12.
i know you're thread started off not asking about 'what' oil to use, but like any oil related thread, it started morphing that way and i figured since you were going to walmart anyway.....
Old Aug 10, 2020 | 06:22 PM
Dano523's Avatar
Dano523
Don't run 20-50 in the primary. It's too thick, and will cause fluid dynamics drag since the oil can not clear the plates fast enough on lever pull, and will cause excess slip on engagement from the fluid not able to vacate fast enough from the plates as well.
Old Aug 10, 2020 | 06:24 PM
hd4evr2008's Avatar
hd4evr2008
Mobil 1 15w 50 has more zinc in it than most so called motorcycle oils....
Zinc Level 1300 ppm
Old Aug 10, 2020 | 06:33 PM
handirifle's Avatar
handirifle
Never intended to, see above posts.
Old Aug 10, 2020 | 06:35 PM
handirifle's Avatar
handirifle
Skratch
You are saying rotella for the primary? Thats easy, since I use that in my Duramax.
Old Aug 10, 2020 | 06:41 PM
handirifle's Avatar
handirifle
Ok issue settled. Ordered (not available in stores here it says) the oil change kit, with 4qt vtwin 20-50 and k&n filter. Will prob use the rotella in primary, and whatever I decide on for gearbox, when time comes
Thanks to all
Old Aug 10, 2020 | 07:32 PM
Neggy ZRXOA 5248
Valvoline VR1 non synth is 1200 PPM Zinc, and with my shop discount it us about 5 dollars/quart
Old Aug 10, 2020 | 07:50 PM
Red's Avatar
Red
I disagree with you and the MOCO disagrees with you! 20/50 is fine for the primary.
Old Aug 10, 2020 | 08:05 PM
handirifle's Avatar
handirifle
Mobil 1 V twin is 1600
