Oil change question
Old Aug 10, 2020 | 08:09 PM
Hawg Runner's Avatar
Hawg Runner
I agree with Red. I have been using Amsoil 20-50 in all three holes every 5,000 miles, 18,700 miles now with no problems. 19' FLHXS.
Old Aug 10, 2020 | 08:29 PM
skratch's Avatar
skratch
Originally Posted by handirifle
Skratch
You are saying rotella for the primary? Thats easy, since I use that in my Duramax.
yep. been using that for years. never had any issues.
Old Aug 10, 2020 | 08:42 PM
metalman82's Avatar
metalman82
6th Gear
I ran the Mobil V-Twin 20-50 and the valves rattled like hell. The engine sounded awful. Switched back to the SYN-3 and it runs quieter. I am running Red Line Synthetic Primary along with Red Line Synthetic Transmission with Shock Proof oils. It all is a personal preference deal. I do run the K-N Filters.
Old Aug 10, 2020 | 09:29 PM
handirifle's Avatar
handirifle
Metalman
Thanks thought I would give synthetic a try. Worst case they rattle and I know better. Will see
Old Aug 11, 2020 | 07:32 AM
thebreakman's Avatar
thebreakman
Amsoil products and K&P Engineering Hi Flo oil filter.
Old Aug 11, 2020 | 01:54 PM
hardheaded's Avatar
hardheaded
I've ran Mobil V-Twin 20-50 on the primary of shovelheads and my Evo bikes for many ,many miles and some friends have been running it their twin cam bikes for thousands of miles without any problem at all.
Old Aug 19, 2020 | 01:41 PM
handirifle's Avatar
handirifle
Question for primary. Manual shows drain plug location, and removal of clutch insp cover, but for refilling does not say how to check level. I assume, with bike level, I fill it to bottom clutch inspection opening?
Old Aug 19, 2020 | 02:17 PM
eighteight's Avatar
eighteight
You do not. That will be overfull
Observe the level on the hub ( derby cover off) prior to draining.
Add the # of ounces spec`d for your bike
Observe that the level is now close to first view
Old Aug 19, 2020 | 02:20 PM
handirifle's Avatar
handirifle
Ok glad I asked. I saw it's 38oz for "wet" refill. That surprised me, since trans only take 28oz. I figured would be the other way around. Ok so no real level mark. Thanks
hattitude's Avatar
hattitude
