Some question about an 07 Ultra
It has dealer installed Bub Rinheart(sp) true duals, an oil cooler, and from wha I can find out, no mods to the intake or the EFI code (stock download?).
The dealer did the 1000 miles service and there were no complaints noted or found.
They put in SYN3.
I've only ridden it a little, to work and back and to lunch. I have not noticed any problems with excessive heat. But then again I would not know it unless it burned my leg at a stop light.
I've read about overheating problems, and was just wondering if the former owner applied the right mods and I shouldn't let it worry me. I'm not much into tinkering, so I won't mess with it unless it is broke. I just want to ride, ride, ride.
I've been riding all my life, 1000cc, 1500/1600cc and most recently the 2053cc Vulcan. Bikes are not new to me, but this is my first Harley (I'm 54).
If I need to, the ThunderMax unit is probably what I would get, and some form of better breathing intake. So far, 96ci is plenty and I don't miss the tons of torque (100hp and 133 tq)on the 125ci Vulcan (much).
Thanks for any responses, and ride safe!
Greg
Wichita
http://www.noller.net
We can all put in our .02$ worth, but if you are happy with it stock then RIDE IT! If you want to see the bikes potential then put in a SERT or ThunderMax and you'll wake the bike up and cool the engine down. Either way you have a nice scoot!
there are some "gear heads" on this site, and then there are those of us (I saw it typed here before "gear heads") who repeat the same as gospel. FYI, I'm not a gear head, but I don't think I'm entirelyignorant either. Somehow the notion of reduced back preasure (true duals) could causea lean condition oroverheating is possibly incorrect.Loss of torque at higher RPMs and performance, you bet. Excessive heat or lean condition, seems questionable?? This non-gear head doesn't understand.Increasing the air flow (breather intake modifications) can lead to lean/hot engine conditions. Reducing back preassure? I just don't understand............
at least that's what I've read here from other dipsticks like myself..............
I guess this is what I will do:
ThunderMax with Auto Tune, K&N Stage 1 air filter kit. Orderd and shipped. With the Ture Duals from BuB/Reinheart, this should make nice power.
For oil, Mobile 1 15W50 in the engine, Mobile 1 20W50 Motorcycle Oil in the Primary, and Mobile 1 75W140 in the Transmission.
Air in the tires will come from my own compresser.
Greg
Wichita
07 Ultra
Welcome to the forum! Many on this forum have switched to the Metzler ME 880's. A friend of mine that bought my oldgoldwing switched to the 880's and let me take it for a ride afterward. The difference was very noticeable. I just replaced the rear tire on my ultra with a Dunlop. Next time when I replace both front and rear tires it will be with 880's. Avon also makes a good tire.
