Clacking issues remain.
Old Aug 25, 2020 | 04:26 PM
Jazz Singer's Avatar
Jazz Singer
Question Clacking issues remain.
Still having noise emanating from somewhere. Seems to be a metallic clacking noise from the lower front during mild acceleration and light cruise. Under hard acceleration it quiets down considerably. Idle and light load is terrible. I'm going to pull the primary cover but am wondering what I should be looking for. I'm aware of the compensator nut backing loose, but is it possible the chain could act this way if too loose? The motor has less than 5k on it and was quite stoutly built. The previous owner was no techie so he really didn't even understand what he was telling me. Here is what he told me.
96" (All Screamin Eagle Parts)
high output cams (255?)
HTCC pistons
Heads ported and polished
High performance oil pump
Thunder Header 2 into 1 exhaust
Mild mapping done to ecm
Compression release valves
I guess, I'm wondering what else I should look at if the compensator nut is not loose.
Old Aug 25, 2020 | 04:45 PM
eighteight's Avatar
eighteight
[QUOTE=Jazz Singer;19356479]Still having noise emanating from somewhere. Seems to be a metallic clacking noise from the lower front during mild acceleration and light cruise. Under hard acceleration it quiets down considerably. Idle and light load is terrible. I'm going to pull the primary cover but am wondering what I should be looking for. I'm aware of the compensator nut backing loose, but is it possible the chain could act this way if too loose? The motor has less than 5k on it and was quite stoutly built. The previous owner was no techie so he really didn't even understand what he was telling me. Here is what he told me.
HTCC pistons
Compression release
have you checked push rod / lifter preload?
Many a noise has been diminished by another half turn of preload
Old Aug 25, 2020 | 05:20 PM
Jazz Singer
No, I haven't done that because because it goes awaynunder load. This isnt a ticking noise. Do these lifters make a metalkic clacking noise? I do have adjustable pysh rods. I could check them.
Old Aug 25, 2020 | 09:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Quit possible the primary chain tensioner needs adjustment or is shot and the primary chain is flopping around hitting the case.
Old Aug 25, 2020 | 11:01 PM
Jazz Singer
Kinda what I was thinking when it goes away under hard acceleration. Gonna pull the cover off when the gasket gets here.
Old Aug 26, 2020 | 05:37 AM
MikeTD3's Avatar
MikeTD3
You can reuse the primary cover gasket many times over.
Old Aug 26, 2020 | 06:11 AM
Jazz Singer
I wasn't aware. I appreciate the info. Guess I'll pop it off today, then. Thanx!
Jazz Singer
Sep 25, 2019 10:51 PM
STLBagger
Aug 8, 2016 11:48 PM
customsoftail200
Apr 2, 2010 09:21 AM
FLHXXHLF
Exhaust System Topics
11
Nov 20, 2008 09:22 AM
dlocke67
Oct 25, 2008 10:24 PM
