Radiator Removal
Old Sep 9, 2020 | 11:14 AM
Texcuda's Avatar
Texcuda
Default Radiator Removal
I have an issue with removing the lower radiator bolts from the driver's side lower fairing on my 2017 CVO Ultra. The bronze inserts the bolts thread into are just spinning in the plastic lower fairing. There isn't enough threads to run a bolt in from the rear, and can't weld to it for multiple reasons. Anyone run into this issue and how did you solve it?
Old Sep 9, 2020 | 11:33 AM
00fxst's Avatar
00fxst
I just put a water pump in my limited and had the same problem.Take off the outer grill and drill through the flat part of the insert and just a little bit into the plastic with a 3/32 bit and hold it there,the bit will keep it from spinning.
Old Sep 9, 2020 | 03:58 PM
Texcuda's Avatar
Texcuda
Now, why didn't i think of that? Many thanks sir!!!
Old Sep 10, 2020 | 07:48 AM
00fxst's Avatar
00fxst
your welcome,i know this works because all 4 of mine spun
Fireball Jack
Audio Systems
Feb 13, 2020 11:11 AM
ShrinerRider
Aug 17, 2017 12:42 PM
jma100
General Topics/Tech Tips
Mar 14, 2015 08:08 AM
KCFLHRC
Feb 15, 2011 09:11 AM
Blacklion213
Oct 22, 2008 09:12 AM
