Lower bolt to Outer Fairing stripped
Old Aug 7, 2017 | 05:55 AM
ShrinerRider's Avatar
ShrinerRider
Default Lower bolt to Outer Fairing stripped
I am trying to remove my outer fairing on a 2012 Ultra. The lower left bolt is out about 1/4 of an inch and will not loosen or tighten any. I have tried putting some pressure on it with no luck. The head is good, it is like the threads are stripped. Any ideas on getting it out, or is it time to start drilling??
Thanks,
Jason
Old Aug 7, 2017 | 07:14 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
It sounds like the brass insert in the fairing that the bolt screws into has separated from the fairing.
Take all the other bolts out. Have someone hold the fairing and pull back on it with some pressure while you try to loosen the bolt. It should come out, or the brass insert will separate from the fairing.
The good news is the dealership as a repair/ replacement insert.
Old Aug 7, 2017 | 07:16 AM
Hoginedgewood's Avatar
Hoginedgewood
On my o6 there is a brass insert in the plastic, maybe your insert is pulling out. Try having someone pull out on the fairing while your turning the screw.
Old Aug 7, 2017 | 03:14 PM
470004's Avatar
470004
Like the above stated, the brass insert is strip. Harley sell a repair kit or aftermarket kit.
Old Aug 7, 2017 | 06:55 PM
Veekness's Avatar
Veekness
...and at the risk of saying this one too many times. ..that slot in the inserts is not for a screwdriver! It's for thread cutting.
Old Aug 17, 2017 | 09:01 AM
ShrinerRider
Thanks
Old Aug 17, 2017 | 09:12 AM
pp6000v2's Avatar
pp6000v2
What is that little installer bit in the pic? I've had to replace a few inserts and I like baubles, so I'm completely interested now.
Old Aug 17, 2017 | 11:24 AM
VDeuce's Avatar
VDeuce
The insert is turning. I had to grind the head of the screw off to get one to release, then addressed the insert.
Old Aug 17, 2017 | 12:42 PM
pp6000v2's Avatar
pp6000v2
I did have the issue of the lower left insert on the outer faring come loose because the plastic standoff it was in was splitting down the side. With a new insert, I mixed up some JB KwikWeld and molded the insert back into the plastic standoff. It has held up for a couples years now with no deterioration.
kryingame
Apr 3, 2017 02:35 PM
kryingame
Sep 6, 2014 10:40 PM
AlanStansbery
Oct 19, 2013 11:56 PM
Guitar4Him
May 1, 2011 08:40 AM
Jags93
Jan 4, 2011 03:51 PM
