Rectifier wire
Old Sep 15, 2020 | 07:42 PM
Jers420's Avatar
Jers420
Default Rectifier wire
While I was cleaning my bike I noticed that 1 of my rectifier wires look like it was crushed and it's showing exposed crushed wire. My question is can I cut and repair or Do I have to buy a new rectifier?
Old Sep 15, 2020 | 08:06 PM
Musician's Avatar
Musician
If you are referring the double wire plug that goes to the regulator/rectifier, yes you can repair it. I just did that in my FLHT, and took it on a 2,000 mile trip with no problem. YRMV, depending on how you go about fixing it.
Old Sep 16, 2020 | 11:35 AM
Jers420's Avatar
Jers420
Yes that's the wire. I was gonna cut it and use a wire connector.
Old Sep 16, 2020 | 11:39 AM
merlin 2's Avatar
merlin 2
cut , solder, shrink rap. is better
Old Sep 16, 2020 | 07:28 PM
Ragtop's Avatar
Ragtop
Merlin is right, don't use a wire connector IMO
Old Sep 16, 2020 | 08:05 PM
MyFavRk's Avatar
MyFavRk
Like stated , solder is the only way to go . Make sure you do an inline solder and put two layers of shrink tube over it . The first shrink tube will cover the solder joint and some of the wire on each end , where the second one will be a little longer to cover more of the wire and prevent any moisture from sneaking in . Lots of videos on how to in line solder , easy peasy , just make sure you use the same gauge wire and a peace long enough to get the job done . Good luck !
Old Sep 16, 2020 | 08:21 PM
Jers420's Avatar
Jers420
Ok thanks for everyone's help. I'll get on it tomorrow.
Old Sep 16, 2020 | 10:15 PM
OkieBill's Avatar
OkieBill
This ☝🏻. Done as described above and it’s a very solid connection that will last. Fix and forget.
Old Sep 16, 2020 | 10:59 PM
TriGeezer's Avatar
TriGeezer
I’ve been using the kind of things lately, and they’re working out well. I do put heat shrink tubing over them,
TICONN 150 PCS Solder Seal Wire Connectors, Heat Shrink Butt Connectors, Waterproof and Insulated Electrical Wire Terminals, Butt Splice (150PCS)
Amazon Amazon
Bill wallace
Shovelhead
27
Feb 16, 2021 08:00 AM
zivkos
Mar 24, 2019 09:45 AM
bobbyjoes
2014-2024 Touring Models
May 5, 2017 08:42 PM
Danielc409
Jul 8, 2013 01:16 PM
stl jeanes
May 26, 2013 02:56 PM
