LED front turn signals cause fast dash lights.
Old Oct 20, 2020 | 08:52 PM
Slick40's Avatar
Slick40
Stage I
Question LED front turn signals cause fast dash lights.
2119 FLHTK, I installed the H-D front turn signal inserts and followed the procedures listed in a link, didn’t work.
  1. Turn Ignition on, but do not start the bike.
  2. Turn on 4 way hazards by pressing the hazard button on the controls. Note: DO NOT press both turn signal switch's at the same time. That is the way the hazards activate on PRE CANBUS bikes.
  3. Turn the Ignition off letting hazards run. IF the bike has security they will flash 5 or 6 times and then pause. This is normal. They will go back to flashing normal hazard mode.
  4. Let hazards run 1-2 minutes.
  5. Turn Ignition back on.
  6. Turn off hazards.
  7. Turn Ignition off and then back on.
  8. Check function of both turn signals.
Secondary Turn Signal Sync Procedure (If Needed)
  1. Turn Ignition on, and start the bike.
  3. Let hazards run 1-2 minutes with engine running.
  4. Turn off hazards.
  5. Turn Ignition off and then back on and restart the bike.
  6. Check function of both turn signals.'
Tried leaving 4-ways on for 10 minutes, reset BCM by pulling main fuse for 10 minutes, erased codes in BCM before and after. Always comes back with same codes, b2141, b2146. Also after riding for an hour or so the white lights will go out and sometimes the amber will flash without the turn signals on. Heat related maybe, I live in AZ. Any insight would be appreciated.
Old Oct 20, 2020 | 08:57 PM
RangersRG's Avatar
RangersRG
I just plugged mine in like you would if you were changing bulbs. I have a 20 RG.
Old Oct 21, 2020 | 04:53 AM
GalvTexGuy's Avatar
GalvTexGuy
Installed HD LED inserts on my '20 Heritage. All I did was turn on the hazards and let them flash 12 times. Double-check your wiring.
Old Oct 21, 2020 | 09:10 AM
Ssitruc's Avatar
Ssitruc
Also, while you're re-checking your work, be sure to wipe any grease out of the sockets best you can.
I put CD LEDs in and remember reading that not getting the grease out can cause annoying issues... LEDs draw such little current.
Old Oct 21, 2020 | 09:54 AM
billib1954's Avatar
billib1954
My dash flashes rapidly, signals work correctly.
don't care.
Old Oct 21, 2020 | 12:12 PM
bottomgun's Avatar
bottomgun
Thank you for that. It worked for me. I was getting ready to call CD to see what the issue was.
hydrantwrench
Electrical/Lighting/Alarm
20
Apr 1, 2020 09:15 PM
BigDipper15
Nov 19, 2019 04:18 PM
santajim
2014-2024 Touring Models
25
Mar 30, 2018 06:31 PM
Reindeer
11
Sep 27, 2012 06:34 AM
wayne smith
Apr 25, 2011 03:41 PM
