Stripped Flairing Windshield Screw - Help
Old Jul 28, 2007 | 07:37 PM
valleyrider's Avatar
valleyrider
Default Stripped Flairing Windshield Screw - Help
I seemed to have stripped the front flairing windshield bushing when I re-installed the front half of the flairing.
Any ideas on how to fix/replace. The biggest problem I see is getting the hex screw out as it just keeps spinning, bushing and all.
Any advice would be greatly appreciated.the bike isstill under warranty, would this be covered?
Old Jul 28, 2007 | 07:48 PM
raftgyde's Avatar
raftgyde
Default RE: Stripped Flairing Windshield Screw - Help
ORIGINAL: valleyrider
Not a problem. The bushing HD installs press in. Go to your dealer. Walk up to the parts counter. Tell them what happened. They have replacements that are threaded and will screw in instead of press in. Go ahead and get 3. The other two will loosen up eventually. I went ahead and replaced all 3 of mine after the first one stripped. Don't worry about this. You are definitely not the first (or last) guy to do this.
As far as getting the stripped one out, I'd pull out all the screws except that one. It might pull right out with the fairing or when you pull on the fairing, you might put enough pressure on it that the bushing won't turn when you unscrew it.
One note, when you put them in. They're soft brass with a slot. The ends will break off where they're slotted. After I broke the first two off, I used a screwdriver to start it and then a pair of needle-nose or vise-grips to turn it in the rest of the way. I screwed them all the way in until I couldn't screw them anymore.
Old Jul 28, 2007 | 07:52 PM
soos's Avatar
soos
ORIGINAL: raftgyde
Not a problem. The bushing HD installs press in. Go to your dealer. Walk up to the part counter. Tell them what happened. They have replacements that threaded and will screw in instead of press in. Go ahead and get 3. The other two will loosen up eventually. I went ahead and replaced all 3 of mine after the first one stripped. Don't worry about this. You are definitely not the first (or last) guy to do this.
The threaded insert you need is HD # 16585-96. Try installing the insert by using the the screw that holds the fairing on. Screw it all the way into the insert and then drive the insert into the fairing by driving the screw.
Old Jul 28, 2007 | 07:58 PM
harleybuilder's Avatar
harleybuilder
Use a ( if i remember correctly) 3/8" bottom tap in the holes and the replacement inserts will screw right in and stay tight.
Old Jul 28, 2007 | 08:01 PM
soos's Avatar
soos
ORIGINAL: harleybuilder
That would be a 3/8-16 tap.
RonH's Avatar
RonH
That way I just replaced mine was to use a nut as a spacer between the new brass insert and the windshield screw. The slotted end goes into the inner fairing, the slots cutting the path for the insert. The nut takes up the space on the screw so you can simply use a screwdriver and screw the insert into the hole all the way.
Old Jul 28, 2007 | 08:06 PM
harleybuilder
soos, you are correct.
Old Jul 28, 2007 | 08:20 PM
valleyrider
Thanks guys, this site is the greatest.
Old Jul 28, 2007 | 08:23 PM
soos's Avatar
soos
Just need your address now for billing purposes.
Old Aug 18, 2008 | 08:17 PM
izzi's Avatar
izzi
thanx, just realized sunday i have one stripped too.
i am going to replace the 7 screws all around as well(that hold outer fairing)
