Issue with my J&S Jack
Old Oct 27, 2020 | 06:28 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Originally Posted by kryingame
Okay. time to eat some crow. I spoke to J&S today. Stupid me, I had the safety stops to far/deep into the floor. I don't know what I was thinking because I've had the jack for 3 -4 years now. Also, I needed new rubber boots so they don't damage my bike.
Guys, I really appreciate the help. I definitely had a dumb moment.
It happens to everyone at some point, chalk it up and move on!
Ride safe!!
Old Oct 27, 2020 | 07:25 PM
Notgrownup's Avatar
Notgrownup
You don’t know jack apparently.lol ahahahah
Old Oct 27, 2020 | 09:11 PM
hattitude's Avatar
hattitude
Originally Posted by RKZen
Does the castor come up as soon as you start lifting or at a certain height? I would check the welds with bike on and off the lift. Also check if any of the bolts are not loose. These have a lifetime warranty, so any defects and you're covered.
Off topic - Do those locking screws do a number on the floor coating? I have the same coating and I put down a thin rubber square under them.
Yes they can damage the floor coating.....!
I have a professionally applied epoxy coating on my small HD shop floor.... The first time I used the J&S on that floor, my locking screws still had the rubber caps on them... I screwed them down, to make sure the bike didn't roll.... they actually poked through the rubber caps, and put a chip in the floor epoxy... I may have screwed them down too much....
After that, I stopped using them. My shop floor is perfectly level....
If I'm going to do some heavy wrenching on the J&S jack, instead of on my lift table, and I am concerned the jack may move... I have thick rubber pads I put under the jiffy stands... Once the bike is in the air, I put the jiffy pad stand under the screws and then screw them down... but not too tight...!
Old Oct 27, 2020 | 11:19 PM
LQQK_OUT's Avatar
LQQK_OUT
Rubber boots? If you are referring to the rubber pads on the support rails, you can get some Baler Belting from Tractor Supply. Clean rails on jack, cut-up belting to appropriate size and glue down with Shoe Goo.
Old Oct 28, 2020 | 08:52 AM
RKZen's Avatar
RKZen
I now use a 2"
square steel plate and glued a thin rubber pad on the bottom. Works great for me.
Old Oct 28, 2020 | 09:34 AM
Rob175's Avatar
Rob175
My J&S Jack twists a bit as I raise my Ultra Limited....BUT that's because my garage floor is sinking in the middle. I try to place the jack at the lowest portion of the floor's dip but I still have one caster that sometimes doesn't make full contact with the floor until I begin pushing the cycle and jack into it's proper parking spot in my garage.
I learned 6 yrs ago, when I first bought the jack, to NOT screw down those two screws until it was parked in its proper spot.....they are really just to keep the jack from rolling when stationary.
creepy
General Topics/Tech Tips
Feb 14, 2019 04:35 AM
BMyers
May 4, 2014 09:00 PM
skully1200
Feb 7, 2012 09:18 PM
Talldog
Sep 20, 2010 10:49 PM
cramil
Apr 28, 2009 01:49 PM
