Sears Yellow jack for a Softail Modification, with pics.
I know Harley makes "Frame Protectors" for this, but here is a different idea if you have the Sears jack.
The Sears jack comes with two extra plates in case you have a dirt bike with a higher frame and need more lift height. I didn't need them, so I cut off the mounting shafts on the back of the plates.
I then removed the rubber bumpers, drilled holes, and attached the plates to the jack at the same distance as the frame rails on my Heritage. Then I used Contact Cement to re-glue the rubber bumbers back down.
The extra height is just enough so that the jack contacts the frame and misses the shocks while still being low enough to fit under the frame rails. Works pretty good.
Yes I know there are times when you need the jack out of the way but I usually aim to balance the bike on the jack so that the straps just keep me from doing something stupid, not hold the entire weight of the bike. So is my heritage an oddity or am I missing something?
Personally I think it looks like an accident waiting to happen jacking it that way!
This way though, wherever you need to lift, you don't have to worry about hitting the shocks instead of the frame.
