Issue with starting
Old Nov 4, 2020 | 06:39 PM
Rob Courtier's Avatar
Rob Courtier
Default Issue with starting
Ok, about to the end of my rope on this one.
No oil pressure light, no start, relays click, but nothing. Replaced oil pressure sending unit, check all connections and wires, all good, but it only clicks the relay on the left and the ones to the ECM, but starter won't engage at all.
Checked TSSM, and everything I can think of.
Here's the rub....before all this happened, no problems.
Then it started not wanting to start at times, then not at all.
Oil light came on, then not at all. Checked bulb, to .
This is a rebuild from the ground up, and everything was checked as I reassembled it, along with grounds. A new(used) wiring harness, and it started right up!!
Now, power to everything, but nothing else but the one relay in the left cover and 2 in the ECM on right. And no oil light!!
Old Nov 4, 2020 | 06:42 PM
CoolBreeze3646's Avatar
CoolBreeze3646
And what are we talking about?
Year & model of the motorcycle may be useful if you would like input
Old Nov 4, 2020 | 06:56 PM
mfortkamp's Avatar
mfortkamp
The starter relay might have a bad connection internally. Do you have a volt meter that you can check to see if you are getting power to the little wire on the starter?
Old Nov 4, 2020 | 07:05 PM
Rob Courtier
Guess I should have put in year and model.
It's a 2001 Electra Glide with Ultra wiring harness.
Changed out all relays, and no change.
But the oil light worked before and now won't.
The starter relay clicks, but nothing else.
Hope this clears things up a bit.
But, as mentioned I'll check the wires to solenoid again
Old Nov 4, 2020 | 07:45 PM
CoolBreeze3646
Okay, you probably have already done this but have you checked the battery (get it load tested) sometimes they can show good voltage but not put out the amperage.
How old is the battery? Is it fully charged or put on a maintenance charger when not in use?
What is the voltage of the battery when the motorcycle is not turned on? If it is 12.5 volts or lower, see if it will charge up, should be around 12.8 - 13.5 volts. Use a volt ohm meter and not the voltage meter on the motorcycle.
Then check the voltage while trying to start the motorcycle, it should drop some but not below 10 volts.
You may also want to check the cables that hook up to the battery as sometimes they get corroded internally under the insulation.
Old Nov 4, 2020 | 08:17 PM
MyFavRk's Avatar
MyFavRk
Good chance you may have a bad cell in the battery , as cb stated , get your battery load tested .
using a volt meter , remove the single wire going into the starter , neg on battery post , pos on connector , you should be getting 12v + with ign on , only when you hit the start button . With the other issues your experiencing , I would guess bad battery or cables . There are grounding points as well , just ahead of the battery , down below the rear of the tank , check those , clean and tighten .
Rob Courtier
New battery, and cable .
Fully charged.
Old Nov 4, 2020 | 08:33 PM
MyFavRk's Avatar
MyFavRk
Have you checked the system relay , Check for corrosion , clean it up with some electrical contact cleaner and inspect wiring for damage , loose or broken pins .
When checking the ground pole under the tank , remove and clean up all the connections with some fine emery cloth , then check for any connectors that may be breaking off .
Old Nov 4, 2020 | 08:40 PM
Rob Courtier
I own a load tester, and have used it.
I have really done everything that I can think of to solve this problem, but I must be missing something.
I've metered, checked, tested, and replaced everything I can think of , with exceptions of the ECM itself. I don't have that equipment for that. But have some other ideas to check again. Also, the TSSM supposedly has a battery in it with no way to check it that I've found. But, I can't understand why the low oil pressure light was working before, but now won't. Confusing. As I understand, if the ECM can't "see" the sensor, it won't let the motor start! Am I correct in this?
Old Nov 4, 2020 | 08:52 PM
Rob Courtier
Yes, all checked, cleaned and checked again.
The very first thing I did.
I do my best to be thorough.
