Issue with starting
Old Nov 5, 2020 | 08:01 AM
CoolBreeze3646's Avatar
CoolBreeze3646
The only other thing I can think of is something went wrong with the ignition switch and it is not contacting something causing the failure. Hopefully something will show up so you can get the issue corrected.
Old Nov 5, 2020 | 08:09 AM
Rob Courtier's Avatar
Rob Courtier
Still, the thing that baffles me, is the low oil pressure indicator, which worked before fine and now doesn't work at all. It is tied into, according to the schematic, directly to the ECM. I just hoping I don't have a problem with it as these things arent cheap, and with the economy the way it is at the moment, it'll be a while before I can get another.
The bike set in a friend's garage for a few years, and on this bike shop's rack for another year. And I've been working on it for the last year. It was totally stripped down, powder coated (yes I cleaned off all the grounds), repainted, an motor gone through, rewired, and reassembled. My friend passed away just over a year ago, so I can't ask him anything about it. But as I've redone literally everything on it, it wouldn't do any good.
Old Nov 5, 2020 | 08:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t worry about the ECM or the oil pressure light yet, neither has anything to do with the no crank issue.
One step at a time.
Old Nov 5, 2020 | 08:49 AM
Rob Courtier
Yep, but I know the TSSM does have something to say about it. I have the official HD shop manual for it, and it shows that the starting system is tied to that thing. Add electronics, buy aspirin! The starter relay does click when I hit the start button, so it's all working back to there. So now, to check the way out of the relay. I will beat this thing.
Old Nov 5, 2020 | 08:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The TSSM controls the ground for the coil in the relay, but if the relay is clicking when you press the start button it tells us that part of the circuit is working properly.
The relay should get continuous power at pin 30 when the ignition switch is on.
Old Nov 5, 2020 | 08:57 AM
Rob Courtier
I'll be checking that today.
I'll let you know.
Thanks for the "heads up."
Old Nov 5, 2020 | 09:13 AM
Rob Courtier
Yes, am getting power to pin 30 ( or "E" in the manual).
Old Nov 5, 2020 | 09:16 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Now you need to read the voltage coming out of the relay (pin 87).
With relay installed try sliding it out of the connector slightly so that you can get your voltmeter probe on the connector tab (87), it should have power when the start button is pressed.
Don`t disconnect the wire that goes to the solenoid.
Old Nov 5, 2020 | 09:27 AM
Rob Courtier
Yes, maybe about 5 volts
Old Nov 5, 2020 | 09:29 AM
Rob Courtier
Then it drops off a bit.
