Hello fellow riders, I sold my 2013 Non ABS Softail Deluxe and bought my firs ABS motorcycle a 2008 Screaming eagle Road King It has a front rim that is an aftermarket 21" rim with a one rotor setup a brembo caliper with the a speed sensor ring zipped to the brake line. The brake line has been replaced with a single magnum shielding brake cable that goes into the ABS module. I took the wheel off and it has a non abs bearing installed instead of the ABS type. If I replace the bearing do you think it might work or will I have to have both dual sensors on the wheel with 2 ABS bearings on the rim for this to work? Last thought or should I just forget the ABS all together and leave it as is, your thoughts on this would be appreciated. Thanks
ABS bearing only goes on 1 side, there is also only 1 sensor. As prevously noted, the ABS bearing is wider, you will need to change the spacer on the ABS side.
